AH FabricationsEM Tuning
    quattrokid's Avatar
    Jan 2006
    Ayrshire Scotland U.K
    220
    Traction control light & ABS light sometimes comes on
    What's causing this?
    Had similar on the RS4, turned out to be a broken toothed gear ring on the drive shift hub... also when the lights are on, on the S3 it judders to a stop below 20mph.
    Is it the same problem? It can be days between illuminating again so intermittent at the moment.
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
    May 2013
    21
    did you sort this?
