Thread: coded key AGU
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    coded key AGU
    I bought a switchblade key, as I currently only have 1 key for the car. I was wondering, A) do most key cutting places cut audi style keys and B) do I need to get some kind of code in it, and how would I go about doing that?
    It's a 1998 R Reg A3 AGU.
    It's not got remote central locking
    Thanks in advance
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Sit-rep:- I got the key cut this afternoon. Unlocks the car fine, and starts ignition, however the flashing light with a car and key keeps flashing and when I start the car it immediately cuts out.
    I understand this is because it's not coded to my immobiliser, so my next question is; how do I get my key to recognise my engine?
    epox's Avatar
    Oct 2012
    Glasgow
    479
    if your blade part did not come with a transponder fitted, u will have to get one and fit it, then the transponder needs coded, i think you can use vcds but???. i took mine to a local vag garage and he coded it for £25.
    cheers mark
    Jun 2011
    Great Melton Norfolk
    1,340
    Do you have the SKC it comes on a tag with scratch off covering. might be in the handbook. If you do not have this code you will need to get it from dealer, or someone who has vag commander or vag tacho can retrieve it. It can then be coded with VCDS.
  1. just my custom code remap agu
    By John Spooner in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2012, 19:39
  2. Adding remote locking & coding keys
    By tezmc in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th November 2011, 18:55
  3. Lost key code
    By Rict101 in forum A8/S8 forum
    Last Post: 13th January 2007, 18:40
  4. Replacement Key Coding
    By steve5s in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st June 2005, 10:42
  5. A4 KEY CODE PROBLEM
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th June 2003, 18:13
