Chris NottMonster Motorsport
Results 1 to 8 of 8
    Jun 2010
    96
    Upgrading A3 8L suspension?
    Hi, what suspension would people recommend for an A3 8L SE? Want improved handling from OEM as well as the improved cosmetic look from it being lowered. Car is currently sitting too high for my liking. Alloys are 18" TTs - so want to avoid wheel rub. How low shoudl I go?
    Mostly used for backroads and motorways. I eventually plan to drop a turbo engine in if that matters. Can anyone make any recommendations? Car is a bit of hobby/project for me - in the process of changing to look like an S3 (bumpers, exhaust etc done) - but won't be adding S3 badges etc. I'm a bit a of newbie so please go easy. All help very much appreciated. Many thanks"
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    a lot of people on here will tell you not to bother turboing it as its a lot of work, and as for suspension, do you want fixed, or adjustable height?
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    Cheap ebay coilovers (JOM/Jamex etc), rear ARB and super pro caster bushes for the front lower arms.
    Job done and perfect for any road car.
    I quite often say I'm going to do things.
    Then never do them.
    Jun 2010
    96
    Hi S3clarke. Thanks for the reply. Yeah, I'm not experienced enough to know the work involved but would like more power after fitting the heavy Recaros. Worth getting it chipped even? Anyway, I'm not sure what is best fixed or adjustable - I'd say fixed as I doubt I'll be adjusting once fitted. I just want improved handling and of course better looks. When my insurance is cheaper I will hopefully be able to treat myself to a real S3. Love the shape of thing 8Ls and would love that power. Thanks!
    Jun 2010
    96
    Quote Originally Posted by 16Klappe View Post
    Thanks I'll have to read up on what these are exactly (as I said I'm a noob) but that sounds good. Many thanks for getting back to me.
    Jun 2010
    96
    Hi 16Klappe, OK found JOM coilovers on eBay
    This right? COILOVER SUSPENSION KIT JOM NEW FOR AUDI A3 8L 96 02 FWD | eBay
    Any recommendations on how low to drop it? Was thinking 30mm front and rear. Would that be right?
    For the rear ARB can you recommend any particular makes? What sort of prices should I expect? Some seem quite pricey at over £300. Should add a front ARB too?
    As for the 'super pro caster bushes for the front lower arms'
    Is this right?
    Audi A3 8L (97-02) Front Arm, Rear Bush Kit Caster Increase - SuperPro Poly | eBay
    Sorry for all the questions.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    I got Joms, theya re good for the money.
    Drop-wise, id advise 40mm max otherwise your standard from anti roll bar will start scrubbing on your drive shaft on full lock. If you plan to slam the car then get a front an rear roll bar kit. Eibach are a good kit. yeah they are expensive to buy.
    Personally, I woudlnt bother with the rear roll bar(with your engine), just fully polybush the chassis.
    Jun 2010
    96
    Hey Paradox, thanks for the input.
    You said: " just fully polybush the chassis."
    Something like this do the trick? Or would I need other parts?
    Audi A3 (97-02) Front Arm & Rear Axle Bush Kit - SuperPro Poly | eBay
  1. Best route to upgrading your B6 suspension
    By QuottroA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th June 2009, 14:11
  2. Upgrading from Audi-sport Suspension. Do you know....
    By imported_AudiOwner96 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th June 2005, 13:28
  3. Brake & Suspension upgrade for A8
    By imported_WIL9598 in forum Handling
    Last Post: 11th August 2004, 11:15
  4. Replies: 1
    Last Post: 14th October 2003, 08:02
  5. 2.8Q suspension/rubber/rim upgrades....
    By cstm28Q in forum Handling
    Last Post: 8th August 2003, 07:37
