Volks AutosMonster Motorsport
Results 1 to 7 of 7
    Jul 2011
    11
    Passenger side brake light problem
    Hi,
    My passenger side brake light stopped working on my S3 2002. I changed the bulb, but that did not solve the problem.
    Can someone offer any advice as to what might be causing this? is this a common issue?
    Thanks,
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    I have the same problem, it's an intermittent fault, I'm guessing a bad connection somewhere.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    S3 Paul's Avatar
    Oct 2006
    2,759
    i had this on my 01 S3
    first i thought dodgy connection on the bulb... turned out to be the brake switch on the pedal,
    worth a look as they arent expensive
    Noggy Blue 2001 S3
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    520
    yeah. If you can, scan it to see if a brake light switch fault comes up. Otherwise I would say just swap the brake light switch because it's so cheap. 5 minute job mate, really easy. Had to do mine recently because ALL of my brake lights stopped working (lol)
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Miss read your original post, glanced over 'brake'. Mine's the light rather than the brake light.
    PS3: Broady_11
    Jul 2011
    11
    Thanks for the comments. I'll report back when it's fixed. Cheers
    Jul 2011
    11
    Replaced brake switch and this fixed the problem. Thanks
  1. Brake Light Problem - S3
    By leewatt in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2010, 00:21
  2. brake light problem
    By frankiejr in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd June 2009, 09:50
  3. Brake light problem - searched and none like mine
    By kaos_king in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2008, 09:29
  4. Brake light Problem???
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2007, 12:12
  5. Brake light problem..... (already searched - still need help)
    By a3tdiquattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2007, 07:29
