JMB RetrofitsAH Fabrications
Page 2 of 2 FirstFirst 12
Results 41 to 59 of 59
Like Tree14Likes
Thread: Sandwich's BT Stroker Build....
  1. #41
    Sep 2011
    Scotland Dumbarton
    246
    dont rush back to it mate...get to it when your better.
    Andrew@A.L.D likes this.
    Noggy blue Bam engined S3. Complete with cr turbos stg4 turbo, xspower mani, dp and sports cat, rifle drilled IE rods, 550 injectors, forge 007, badger5 v2 tip, jetex with heatshield, wellycooler, catch can, weitec lowered shocks +springs, 15mm front 20mm back spacers, rtech custom map
    304bhp 290lbsft wmi soon to be fitted along with 986 brembo fronts!
  3. #42
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,788
    Quote Originally Posted by sandwich1987 View Post
    Just purchased this fine lump of metal
    TSR Garrett Tubular manifold and 3" downpipe
    cant wait to see it in the flesh....
    Make sure they weld on the mount for the EGT probe. They missed mine and so far have taken nearly a month to get one sent to me, plus the turbo lines I ordered and they forgot to send. Hopeless.
    It's an awesome looking bit of kit though. A shame it can't be seen when it's on.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  4. #43
    Sep 2011
    Scotland Dumbarton
    246
    Quote Originally Posted by Sam_ View Post
    yeah I emailed them a while ago, and mentioned your dealings with them, hopefully they sort it out for you soon!
    was considering their turbo line kit, but am looking at various hardline options trying to decide is hard man! see what your opinion is when you get yours
    Yeah its a shame to hide it all away its a good looking combo!
  5. #44
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,788
    I wanted to go hard line but getting them made here just would be a ball ache and the place where I'm putting the engine in (and helping with the build) don't have the facilities so I'll have to settle for braided lines and fire sleeve. Not ideal but it'll have to do for now.
  6. #45
    Sep 2011
    Scotland Dumbarton
    246
    [IMG][/IMG]
    s3dave, StaceyS3 and Sam_ like this.
  7. #46
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,788
    Glad they remembered your EGT boss. Still waiting for mine...
  8. #47
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    Just a little update for you mate
    All exhaust ports had the main cutting done, cleaned up the combustion chamber and started on the inlet ports
    Didn't get any picts of the crack and the welding done as that happened the same time i did my arm, Talking about my arm this is how i'm working with it lol
    <tuffty/> likes this.
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  9. #48
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    You fecking mad man Andrew LOL... props mate for getting on with it... looking forward to having a butchers at mine next week when it turns up...
    <tuffty/>
  10. #49
    Jun 2009
    Leeds
    3,472
    Got to get moving with these heads as i've got S3Dave's to do in a few weeks time
    s3dave likes this.
    FOR SALE
  11. #50
    Sep 2011
    Scotland Dumbarton
    246
    Looks great mate! Take it easy tho....appreciate you working on it while your injured.
  12. #51
    Jun 2009
    Leeds
    3,472
    Just finished off the main cutting on the inlets now so i will get on with the emery cloth tomorrow night
    FOR SALE
  13. #52
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    As above, mine will be ready for you this week, but look after your arm first man... No rush...
  14. #53
    Sep 2011
    Scotland Dumbarton
    246
    Just received my bottom end back from the balancer today everything looks good except my fluidampr its a little bit chewed around the edge, not going to be an issue but a bit annoying at the same time![IMG][/IMG]
    [IMG][/IMG]
    I then found out my main bearing clearance and found everything to around 1.6 thou which I believe it within spec. (No 4 came off with the cap)
    [IMG][/IMG]
    I think im going to take my crank into work and get the trigger wheel bolts tig'd to make sure they don't come loose. I am abit nervous about doing up the arp crank bolt by wedging the crank, with my luck I will crack the block!!
    Ive got my flywheel bolts, diamond friction disc and my piston ring sleeve Wiseco piston assembly tool buy cheap coming along with my oil chain and tensioner soon so hopefully by next week I should have my bottom end 90% done!
    thought id throw in a wee diesel picture I took when down on a course at hms sultan seen as we all love them.....
    [IMG][/IMG]
    s3dave, superkarl and StaceyS3 like this.
  15. #54
    Sep 2011
    Scotland Dumbarton
    246
    Small update on the engine front, been waiting an age for a parcel to be delivered so I could get on with the build and it arrived today
    [IMG][/IMG]
    Once I had my piston ring sleeve I set about building up the bottom end. i fitted my crank and torqued up to spec and when I span it I could hear a rubbing noise coming from the trigger wheel, i narrowed it down to the trigger wheel bolts I welded up and found they were catching on some small nubs in the block. So it was off with the crank again and the I got the dremmel out to smooth over the welds,clean down the crank to get rid of grinding dust, re-install torqued up it span freely Next i fitted the pistons using the piston sleeve, lovely bit of kit( probably abit self indulgent when i bought it works a treat) torqued to 55ftlbs and released 3 times then re torqued.
    [IMG][/IMG]
    [IMG]
    [/IMG]
    Next i fitted the front main seal, was a bit of a pain in the arse as i had no tapered adapter to aid sliding the seal on so i improvised and used the neck off a tall slim bottle worked a treat slid over and then bolted it down complete with the sealant, i used the sleeve for the rear main but didn't get any shots as i only had a helper for 5 mins to remove it from the stand then back up.
    [IMG][/IMG]
    also managed to get some stainless steel pipe from my work that was surplus to requirements, will be a while before i get round to mocking that up tho as i don't plan to fit the engine until late spring as its all going to done in my street lol
    Still have to torque up my crank pulley then i can close up the bottom end with my sump, buy new knock sensors and crank sensor and fit the oil filter housing etc then its turbo purchase time once i actually decide on one.....
    <tuffty/> and s3dave like this.
  16. #55
    Sep 2011
    Scotland Dumbarton
    246
    an someone put me at ease here and tell me the timing cog is the correct distance away from the front main seal housing as I think ive seen one were its right up against the face????[IMG][/IMG]
  17. #56
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    they only go on so far mate. Itl be reet.
    just putting this out there, you seen the nice new billet one from IE? Yummy
  18. #57
    Sep 2011
    Scotland Dumbarton
    246
    It won't physically go any further as that's it with the quarter turn added, but once you get a wee doubt it's hard to ignore...lol
    Yeah seen that billet version, with 6 holes for the damper, thate got me para as well now need to locktite my damper bolts on now!
  19. #58
    Sep 2011
    Scotland Dumbarton
    246
    Just a couple of pics of where i'm at just now. Still waiting on buying a turbo, how long is it ok to leave the engine in this state bearing in mind it all has assembly lube on it?
    [IMG][/IMG]
    [IMG][/IMG]
  20. #59
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Mines been sat in assembly lube for a few months... assembly lube is fine... will not go dry.... as always for start is unplug injectors and turn over to get the oil circulating... no need to put oil in at this stage but I tend to take the cam cover off and pour oil over the cams etc before filling completely
    <tuffty/>
  1. Audi S3 - Stroker Big Turbo build.
    By Scullies in forum A3/S3 Forum (8L Chassis)
    Last Post: 7 Hours Ago, 16:12
  2. 2.0 stroker build, custom remap options in the south-east
    By dubmx in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th January 2013, 21:47
  3. 2008cc 20 Valve Turbo Stroker Build
    By IN 2 Deep in forum The Project Room
    Last Post: 29th November 2012, 21:11
  4. 2.0+l 20v stroker build thread (GT2871)
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th November 2010, 09:13
  5. A3/S3 kick builds
    By will_S3 in forum In-Car Entertainment
    Last Post: 6th June 2003, 13:55
