Chris NottEM Tuning
Results 1 to 13 of 13
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,782
    T3 Manifold & Downpipe
    What are people using? I know there's the TSR one but really I can't devote that much wonga to it right now. Looking at a cast manifold. Does anyone know a decent manifold/downpipe combination that fits RHD Quattro?
    This CTS setup is looking to be favourite:
    I've emailed to see if they will sell the wastegate, manifold and downpipe separately.
    Any others? I'm fitting it with a standard .82 T3 in, v-band out exhaust housing on a GTX30.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,468
    I have the CTS RHD kit and the down pipe is different to the one you see above.
    You will find that the down pipe will not fit your turbo as its a GT turbine housing, with the kit above you need a T31 housing
    T31 Turbine Housing for GT3071R/GT3076R/GT35R/GTX30/GTX35 : atpturbo.com
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,782
    Yeah that's just their generic LHD image.
    Did yours fit ok with the correct housing? No other issues? Do you know if they do a v-band downpipe?
    Jun 2009
    Leeds
    3,468
    CTS build the kit around the T31
    Your new GTX turbo runs the same compressor housing as mine, I found that i had to lower the engine in the bay to get the turbo to fit. Not sure if they do it with a V band
    FOR SALE
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,549
    We fitted a CTS GT3076r kit to Hollies TT... the downpipe is reduced to 2.5" from the hotside to fit RHD cars and we had to modify it anyway as the fit is quite frankly rubbish... the first DP they sent didn't even come with a boss for the lambda... had to get another and that didn't fit together well either... noting lined up properly...
    Modified gate pipe...
    More pics and stuff here...
    <tuffty/>
    Jun 2009
    Leeds
    3,468
    Mine fitted fine?
    Everything lined up so i don't know what happened with the above?
    Bad batch, Different welder, damaged jig, just bad luck i just don't know?
    FOR SALE
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,549
    Quote Originally Posted by Andrew@A.L.D View Post
    Mine fitted fine?
    No idea mate... when we dry fitted both DP's the wastegate would not line up.... too much tension to try and pull it back in square... if we had attempted to muscle it in something would have cracked... there ideally needs to be a flexi in the wastegate pipe but Bill welded in a slipper type joint which helped line it all back up and gave a little movement for when it all expands...
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,156
    Mine fitted fine?
    it had 2 x downpipes sent, neither fitted properly or even close to.
    very poor
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    CTS product are usually well apreciated around here...
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
    RIP S3dave
    May 2004
    nr Glos
    7,156
    Quote Originally Posted by Chlippo View Post
    not here.
    supplied lines did not fit either. Drain too short, water lines intolerant to heat, intake pipe way too small.... with comedy K&N filter which is breather size not GT3076 turbo size and 4" intake!
    A lot of work to rework it into something which fitted...
    Pretty dissapointed, enough to never buy another full "kit"... Far better just buying the manifold and making my own... IF I wanted to use that style again.
    bill@badger5.co.uk
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,782
    Not good to hear. Hopefully I can get the same as Andrew's experience and less of yours Bill.
    I'm just planning on getting the manifold, downpipe and wastegate setup. Hopefully the downpipe doesn't have issues!
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    Quote Originally Posted by Sam_ View Post
    I just bought the manifold from CTS (i already had my turbo and WG) as Clay wanted $895 just for the downpipe! So i had a custom downpipe made for £300 and saved some cash...
    Audi S3 1.9 GT30....
    ....that is all
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,782
    Blimey, $900 for a downpipe that may or may not fit. I'll see what he comes back with and report back.
  1. manifold and downpipe fitting
    By Danny Cawsey in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2010, 19:58
  2. GT28RS manifold and downpipe help needed! ARGH!!!!
    By Robbo1144 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2010, 20:50
  3. manifold and downpipe
    By bansheeboyo in forum Sales Questions
    Last Post: 23rd June 2009, 14:17
  4. Manifold and downpipe
    By bansheeboyo in forum Awesome GTI
    Last Post: 23rd June 2009, 09:57
