EM TuningAH Fabrications
Results 1 to 7 of 7
    Feb 2012
    1,160
    Caliper piston stuck. Help!!
    hi guys. ive recently stripped my r32 calipers to have them painted and decided to replace all the seals at the same time. ive started to fit the seals and dust covers. but one of the pistons has made it half way in and wont budge. it will turn fairly easily but not come in or out. has anh one got any tips on this i can try? its really stressing me out so any help would be very much appriciated. thanks. daz
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Its sounds like the piston has tipped a little, pump pliers or an air line would get the piston out, did you lube the seal with a little brake fluid before you put it back together?
    ​Wish Rachel would let me have my TDI mk5 back
    Feb 2012
    1,160
    yes mate coated it properly. im so annoyed. nothing goes right lol. it was going easy then just stopped. i have no way of getti g an air line easily. pump pliers? the open outwards? thanks for reply. daz
    Sep 2012
    Devon
    843
    Yeah if you use a large pair of water pump pliers on the outside edge at the top of the piston (the part that touches the pads) you can do the twist and pull to get it out dude
    Feb 2012
    1,160
    ok great. worst thing is you need 3 pairs of hands. thanks again im going to try this. daz
    Sep 2012
    Devon
    843
    lol i know that feeling well, to hands to pull on the pliers and 2 to hold the caliper
    epox's Avatar
    Oct 2012
    Glasgow
    600
    just take it to petrol station and use there air. if you have a football adaptor put that in the blead hole and connect the other end to the air:
  1. Pushing back rear caliper pistons?
    By Jonay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd October 2010, 23:59
  2. caliper pistons
    By jamesdownthepub in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2010, 13:30
  3. Retracting Rear Caliper Pistons
    By andy110m in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th October 2009, 22:40
  4. Can't rewind rear caliper piston even with tool
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th July 2009, 19:15
  5. Rear Brake caliper piston tool
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th July 2008, 11:29
