Sky InsuranceBadger5
Results 1 to 14 of 14
Like Tree4Likes
  • 1 Post By vfr800
  • 1 Post By BENJAMIN
  • 1 Post By PiranhaMan
  • 1 Post By JudderMan
Thread: Screeching Noise On Startup
    WorkInProgress's Avatar
    Oct 2012
    Scotland
    237
    Add WorkInProgress on Facebook
    Evening,
    My car has started occasionally making what I can only describe as a screeching noise when I start it, much like the noise when (not that I do) you turn the key when the engine is already running. Could my starter motor be on it's way out? Is it not disengaging properly? Always starts first time no problem and only happens now and again.
    Rob
    1999 1.8t AGU Sport 150 5dr
    Fitted
    2.5" Decat Downpipe, 2.5" MeerKat Custom Cat-Back, R32 Wishbone Bushes, Black Diamond 12 Groove Discs, Phatnoise, S2000 Filter, HKS SSQV, BBS CH Rims,
    Koni STR.t Kit
    Awaiting Fitting
    ABT Rear Spoiler, Oettinger Grille, Catch Can
    Wanted
    5dr Black Leather Interior (Golf/Bora/A3)
    Plans
    Flocked Dash, Respray
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    prob starter motor not disengaging properly
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Oct 2012
    Scotland
    237
    Is there a way to remedy or repair this?
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    May 2010
    Bedford
    2,877
    Sounds like the starter for sure. My EP3 used to do it followed by a crunch when starting from cold which was a common problem.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    PiranhaMan's Avatar
    Jul 2012
    Manchester
    90
    Quote Originally Posted by WorkInProgress View Post
    Evening,
    Rob
    funny you should post this as mine has started doing the same... only does it in the morning when the cars cold
    so id be interested to know the best way to remedy it too if anyone can help
    2002 Audi S3
    Ming Blue
    "Gasses go into the turbocharger and spins it... witchcraft happens and you go faster" - Jeremy Clarkson
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by PiranhaMan View Post
    +1 to the starter motor being the likely culprit, it could be the aux v-belt, but that's a bit more random ... and more of a squeel after the engine has started.
    It screeches because the solenoid that spins out and engages to turn the engine over does not immediately return. It gets stuck and screeches.
    There are some guides somewhere for taking it apart and 'repairing' it, however when i touched mine to do this repair ( on a 13 year old A3 ) the starter motor disintegrated.
    I found a place local to me, AJ Components Limited, who had an ebay store selling after market starter motors, it was a heck of a lot cheaper than a new Bosch but it came with a 2 year warranty. Ignition Leads, Starter Motors items in AJ Components Ltd store on eBay! I'm sure there are other places but these guys were friendly and open on a Saturday morning with stuff in stock.
    It seemed good quality, I bought one, fitted it and never had any trouble with it.
    Fitting was pretty simple with very few tools needed, some sockets and extension bars, I did it on the drive in the cold without lifting the car up.
    HTH Liam
    WorkInProgress likes this.
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    BENJAMIN's Avatar
    Mar 2011
    472
    ^^^ this mans spot on. Starter motor is the culprit on 5 speed boxes.
    Blackie_No1 likes this.
    PiranhaMan's Avatar
    Jul 2012
    Manchester
    90
    cheers for the help lads
    (sorry for hijacking your thread rob)
    2002 Audi S3
    Ming Blue
    Oct 2012
    Scotland
    237
    Re: Screeching Noise On Startup
    No problem. Looks like I'll need to replace the starter then eventually, can live with it just now but it's getting a bit embarrassing with all the strange looks I get when I startup
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
    Dec 2011
    630
    My s3 used to make this sort of noise and it was the secondary air intake
    Blackie_No1's Avatar
    Jul 2010
    Ballyclare, N.Ireland
    24
    My wee 1.6 a3 does the same, noticed a few golfs in the town doing it as well. I put it down to the starter but haven't done anything about it yet
    1994 Audi 80 1.6i
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    IIRC this guide should be helpful in removing the starter.
    OVD - Ottawa Vdubbing - View topic - Mk4 Starter removal/cleaning
    It was a couple of years ago that I did this so I remember it being easy, also when I sent to take my start motor apart some bits fell off/broke so I just bought a new one (as my above post says).
    I didn't need to lift my car up but i'm not a fat biffa!
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Mine's been doing it since 2007 according to the receipts I've got. Still works, still screeches. I can live with it...the neighbours can't LOL.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Oct 2012
    Scotland
    237
    Might need to eat my words, since repairing my central locking pump I'm getting a momentary loss of dash lights when starting the car as if there's no power in the battery then it starts. I believe the battery to be good, replaced in November, and I don't see how it could be connected to the central locking so could the starter be on it's last legs?
    Fitted
    Koni STR.t Kit
    Awaiting Fitting
    Wanted
    Plans
  1. Short Screeching Noise on Start Up
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2013, 21:23
  2. Engine "chirping" noises on startup
    By speedicar225 in forum General Technical / How To
    Last Post: 30th April 2009, 18:04
  3. Chirping engine noise on startup.
    By speedicar225 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2009, 13:00
  4. Odd Vibration Noise on startup???
    By NOGAROS3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th August 2004, 19:57
  5. Noise on startup Audi S3
    By RichWalk in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2003, 11:07
