Chaps,
I've got a small leak going on under the S3 which when coupled with my other symptoms, I believe to be PAS fluid (common pipe corrosion issue I think).
In addition, the car has today developed a whining noise which I believe will be the PAS pump running low on fluid (haven't been able to check fluid level yet). My question is this; the whining noise changes pitch with engine revs - would this be consistent with the pump running dry/low on fluid?
Pretty sure the PAS pump runs off the bottom pulley of the AUX belt (am I right?) so I *think* the symptoms will all be consistent - can anyone confirm? Also, anyone know the part numbers/costs for the PAS pipes?
I love this car to pieces but it is literally raping me at the moment - the joys of 10yr old, 100k+ boost monsters eh?!
Dicky A
Dicky A
