AH FabricationsBadger5
    Jul 2009
    32
    2000 Audi A3 1.6 with EML And Traction Light On - Fault Reader Reads Cam Sensor
    Hi, recently purchased a 2000 A3 1.6, drove about 10 miles after picking up and EML and Traction Light come on, bought it privately and called the guy who sold me it and he did not want to know, got to my garage on monday, it comes up with 1 fault code which is the cam sensor, my mechanic advised using a genuine Audi one, So we went for it, also advised replacing cambelt at the same time, which I also went for..
    He did all the work and the lights are still on, when he plugs in to them it brings up the same fault.. as soon as he clears them they just reaccur..
    Any one have any other knowledge on this?
    Much appreciated, thanks
    Sarah x
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    What is the actual fault code?
    <tuffty/>
    Jul 2009
    32
    P0341 - Camshaft Position Sensor A Circuit Range / Performance Bank 1 or Single Sensor
    Thanks x
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    16725/P0341/000833 - Ross-Tech Wiki
    16725/P0341/000833 - Camshaft Position Sensor (G40): Implausible Signal
    Possible Symptoms
    Malfunction Indicator Light (MIL) active
    Possible Causes
    Wiring from/to Camshaft Position Sensor (G40) faulty
    Timing misaligned
    Possible Solutions
    Check Wiring from/to Camshaft Position Sensor (G40)
    Check Camshaft Position Sensor (G40)
    Check Timing
    An implausible signal is one which is not within the range of expected results...
    <tuffty/>
  1. audi a6 avant, problem with oil low level light, and bulb replacement
    By darcar in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th December 2011, 17:35
  2. Audi RNS-E navi with BlueTooth and A2DP support!!!
    By A3SBQ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2011, 10:25
  3. Audi GSM prep with Bluetooth and NO MF steering wheel.
    By dik in forum In-Car Entertainment
    Last Post: 23rd April 2006, 22:44
