JMB RetrofitsSky Insurance
    WorkInProgress's Avatar
    Oct 2012
    Scotland
    237
    Add WorkInProgress on Facebook
    AGU Engine - Pros & Cons
    Just out of curiosity really, what are the good points to owning an AGU engined car and what are the downsides if any?
    I've read various things on the interweb about the management being basic, being able to run an atmospheric dump valve without issues occurring, stronger engine than later ones etc but you never know quite what to believe so thought I'd ask the experts!
    1999 1.8t AGU Sport 150 5dr
    Fitted
    2.5" Decat Downpipe, 2.5" MeerKat Custom Cat-Back, R32 Wishbone Bushes, Black Diamond 12 Groove Discs, Phatnoise, S2000 Filter, HKS SSQV, BBS CH Rims,
    Koni STR.t Kit
    Awaiting Fitting
    ABT Rear Spoiler, Oettinger Grille, Catch Can
    Wanted
    5dr Black Leather Interior (Golf/Bora/A3)
    Plans
    Flocked Dash, Respray
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    872
    Add Vex182 on Facebook
    It uses a large port head meaning better flow as standard compared to say the Bam and Amk inlets.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Lewis583's Avatar
    Mar 2010
    870
    AGU
    Pros:
    Large port head
    20mm wrist pins
    9.5:1CR
    Cons:
    Basic ECU system(Narrowband lambda) (though they can be mapped to provide good power, provided adequate time is spent tuning them properly. E.G. Prawn's track beast)
    Comes with a hairdryer spec turbo in standard trim (K03)
    Standard large port throttle body on OS. Only an issue if going to be used in an S3/other vehicle with throttle body on NS.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    As lewis said really.
    As a short engine to build on/from the AGU is the best, without question. You get a large port head, 20mm gudgeon pins, higher CR than APY/ AMK / BAM (9.5:1 instead of 9:1)
    However, you can fit a large port head and AGU / AEB pistons to any other 1.8T, and you've got the same thing.
    As a complete engine, it's arguably the worst, tiny ko3 turbo that's only good for 190bhp and very basic me3.8 management with cable throttle and narrow band fuelling.
    New cars, like the facelift A3 with the AUM have small port head and 19mm pins, but on a stock turbo this isn't an issue, and the gains from the later me7.5 ecu outweigh the cons for sure, as well as the more preferable 9.5:1 cr
    S3's get me7.5 in the main (me7 on early models) as well as a ko4 turbo, so instantly easier to tune to 250bhp+. S3's also have the larger 20mm gudgeon pins, but still have a small port head and 9:1 cr.
    ME3.8 can't be all that bad, as my hybrid makes more power than any other running on me7.5, but it doesn't have the same safety features, and it can't have all the cool toys mapped in like me7.5.
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    145
    As well as what they've all said, from what I've seen the bolt down coil-packs used on the AGU/AEB seem to be more reliable than the later push on ones.
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,461
    Quote Originally Posted by RobinJI View Post
    The ICM on AEB/AGU is the issue... don't get these bolt downs confused with the later ones on the ME7 narrow band engines... these too seem to have been fairly reliable although the aftermarket ones fail regularly... genuine only for any coil pack in fact... I have seen an APY S3 come in with 4 x new bolt downs bought from ECP... misfired on every cylinder under boost...
    <tuffty/>
  1. Pro's & Con's For Leasing of cars
    By neversaydie in forum General Chat
    Last Post: 24th June 2005, 15:07
  2. diagnostic port on agu engine
    By mlcadman in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2004, 21:47
  3. pros and cons of the A4
    By imported_rycav in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th September 2004, 09:21
  4. Air con, Pros and Cons.
    By jiminniey2k in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd June 2004, 22:31
  5. DSMer looking to get an Audi....pros and cons?
    By ShayneBishop in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2004, 18:13
