EM TuningSky Insurance
Results 1 to 7 of 7
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    Self leveling clips - eBay item
    Are these the same clips that were on offer on this forum?
    Audi A3/S3 VW polo headlight self levelling clips / sockets / brackets | eBay
    Anyone used them before?
    Just found a wobbly headlight and its annoying.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    Also a little confused how to fit them, how would you fit the motor arm to the clip. Slide it in from the end ? As I can't see it being a push on fitting.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    It looks to be the same as the ones that were on here. I assume you screw it on and slide the ball joint thing in from the side and then locate the motor in the HL housing matey
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Look in the group buy section...
    <tuffty/>
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    <tuffty/>
    My narrow mind never thinks to look outside of the 8l forum
    Feb 2006
    Lincolnshire
    691
    I purchased a pair of these last week after seeing this thread, very quick delivery.
    One of my clips was broken, and the other wasn't far behind I'm sure.
    Popped the bumper off today, and removed the headlights, and set about replacing the clips. These billet aluminium machined clips won't go through the motor hole, but you can slide them in through the dipped bulb aperture. Bit of a squeeze, but possible. I removed the bulb etc to give me a bit more room.
    After manoeuvring the clips into the right position and screwing them in with the torx screw from the old clip, the next tricky bit arises! If you angle the levelling motor at 45 degrees through the motor hole, and pull the headlight inners towards it, you can just about slide the motor ball in to the side of it. I used a long screwdriver to help so I wasn't putting too much pressure on the stem.
    Anyway, with a bit of fiddling, they were in.
    Everything is back together and they work great. Hopefully I won't have any more issues. The only downside is if I need to change a levelling motor in the future, I'll have to remove the headlight, but it's not a big job I guess.
    I would suggest these clips would be perfect if they were 2 or 3 mm less in diameter, they could fit through the motor hole then.
    I would have joined the group buy, but I'm impatient! :D
    Audi S3 - 2002MY - Denim Blue
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by Scullies View Post
    'pushing them on' is the best way to break the original ones.
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  1. GROUP BUY - Clips to fix your headlight self levelling system (A3/S3 8L)
    By Sparkesandnoise in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2012, 12:09
  2. Need a clip to fix your headlight self levelling system ?
    By sideways steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2012, 13:20
  3. Another dodgy Ebay item
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2004, 13:40
  4. Ebay item of interest to all S3 owners...
    By Austin in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2004, 18:05
