Sky InsuranceBadger5
Results 1 to 12 of 12
    PiranhaMan's Avatar
    Jul 2012
    Manchester
    90
    clutch issue..... maybe!!!
    had a bit of a strange one this morning
    ... started the car as normal and sat waiting for her to warm up a little and pressed in the clutch peddle
    lifted my foot and the peddle stayed down... couldn't put it in gear so got out and had a look round and nothing appeared to be leaking
    checked round the peddle and all looked normal (apart from it being stuck to the floor!!!)
    ... i gave the paddle a little pull and it went back into position and instantly pressurised
    drove to work, clutch felt the same as it always does and drove back home before without a problem !!?
    had a mechanic friend of mine have a look over it before and he couldnt see anything obviously wrong either
    so im a little confused... what could have caused the peddle to stick like that and is it anything to worry about?
    2002 Audi S3
    Ming Blue
    "Gasses go into the turbocharger and spins it... witchcraft happens and you go faster" - Jeremy Clarkson
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Whats the milage on you car? Have you had the clutch changed at any point? It could be the slave cylinder starting to fail, how heavy doe your clutch pedal feel?
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Pump it a few times, as it could be an air lock due to it being a hydraulic setup.
    If not, it could be the pedal ready to snap.
    Mine did this last week, approached a zebra crossing and luckily put it into neutral and my pedal snapped!!!
    Luckily got it replaced the next day though, its not a major or expensive job, there is a sticky on how to do this if it helps at the top of the page.
    kelk11's Avatar
    Feb 2009
    102
    I had this happen one cold morning about 2 years ago, pulled the pedal back up with my foot and never had the problem since, can sometimes feel sluggish when engine has just been started and seems related to freezing temperatures. Never caused an issue though.
    PiranhaMan's Avatar
    Jul 2012
    Manchester
    90
    thanks for the replies
    @mk1chopper.... mileage is 72k and the clutch has never been done to my knowledge... and the clutch pedal doesn't feel heavy at all
    @nilz... my mate thought maybe an air lock as well so its possibly that as all seems ok now
    2002 Audi S3
    Ming Blue
    Buzzer's Avatar
    Apr 2011
    Dublin
    410
    Clutch master cylinder?
    PiranhaMan's Avatar
    Jul 2012
    Manchester
    90
    Quote Originally Posted by kelk11 View Post
    yeah it was very cold this morning (car was frozen) so im hoping its nothing serious and just a one off as the car feels normal again now
    thanks again for the replies
    2002 Audi S3
    Ming Blue
    PiranhaMan's Avatar
    Jul 2012
    Manchester
    90
    Quote Originally Posted by Buzzer View Post
    hopefully not !!!
    2002 Audi S3
    Ming Blue
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    354
    I've heard from Audi about this happening because of the master cylinder, it very occasionally stops working like that when its cold then starts working again
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    sometimes its just the cold, mines played up a couple of times, but nothing to worry about. yours may just be the same
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    Mine did it when I first had it (of all times it was at a sprint line at Bruntingthorpe against a growling Ur Quattro !)
    It has done it three times in total over nearly 8 years,finally snapped last year and had the pedal replaced.
    PiranhaMan's Avatar
    Jul 2012
    Manchester
    90
    Quote Originally Posted by s3clarke View Post
    thats what im hoping mate... its been fine since and doesnt feel different so fingers crossed
    cheers
    2002 Audi S3
    Ming Blue
  1. Clutch Issue or maybe not.....
    By terrymcg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2010, 19:30
  2. s3 clutch issues
    By S3Matt1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2007, 19:51
  3. DIS Fault or Issue (maybe)
    By wilko in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th August 2006, 11:55
  4. Clutch Issues? TDI QS with Revo....
    By TDI_Boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2006, 13:34
  5. Cold start issues? Maybe it;s your O2 sensor.
    By eddyg in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2006, 02:03
