Sky InsuranceVolks Autos
Results 1 to 11 of 11
    Beanz's Avatar
    Turbo Lag Is Foreplay
    Feb 2013
    Grimsby
    STEERING ISSUE!!!! Help please
    Hi I have recently fitted new tie rods and track rod ends due to all having play, tracked it up after but driving home I noticed I now have play in my steering wheel and constantly having to correct the steering when driving straight as if there is no steering for about half an inch crossing from left to right so as you could expect rather annoying driving on motor way always having to slightly tilt the steering wheel depending on road camber and wind. It's starting to slightly worry me in case it gets worse any ideas ????
    2000, A3 1.8T Quattro ARY
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by Beanz View Post
    Was the tracking done professionally?
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Beanz's Avatar
    Feb 2013
    Grimsby
    Yes It was done by myself at work after fitting the parts, checked for play when I got to work next day and nothing everything is tight just very confusing as it felt fine before I changed parts as it was on the off chance I checked the wheels for play when checking exhaust
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Ah ok sounds like you know what you're doing.
    Were the tie rods and ball joints original audi or pattern? I've had trouble with the steering before on an A3 where my garage fitted pattern parts.
    Liam
    Beanz's Avatar
    Feb 2013
    Grimsby
    Pattern as the company I work for is linked to a motor factors but if there's no play in parts fitted why would I get play now I'm thinking knuckle joint in steering column but why now after new parts fitted ? plus I measured them and matched them to old parts removed as well so proper confused I can live with it but gets more noticeable at speed
    thanks rob
    Feb 2008
    24
    Its either the knuckle or the rack.. Id have thought on a ramp with full access it would be fairly easy to spot if someones in the car shaking the steering?
    Beanz's Avatar
    Feb 2013
    Grimsby
    Quote Originally Posted by Frazzly View Post
    checked it but could not spend to long looking as had jobs in lol
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    Is it safe to be driving your car in this condition on the motorway?
    Hope you get it sorted quickly mate, but I'm concerned that you're still driving around with it as it is.
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    520
    Hi mate, would you describe the car as feeling "skittish" now? And does your steering at low speeds sort of "judder", like it doesn't flow smoothly back to straight after cornering but sort of stutters back?
    Beanz's Avatar
    Feb 2013
    Grimsby
    Quote Originally Posted by The Doctor View Post
    The car is still safe to drive as it feels like a track rod end has play but it has not thats it, not got any worse and only does it when steering wheel is straight going straight a friend had a look today and thinks its the rack but i want to be sure and yes it does feel a bit juddery but think its my front discs not sure thanks for comments
    rob
    Jun 2012
    Redhill Surrey
    629
    Add Grale1 on Facebook
    Hi, did you get to the bottom of your problems as I'm having the same sort of issues, and mine is getting worse, feels very floaty on the front end
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
  1. 1999 8L Goosed Steering Rack - HELP PLEASE!!
    By Robbo87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2012, 19:25
  2. Audi S4 (2003) Diversity Aerial issues??? HELP PLEASE!!!
    By Lion Heart in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th December 2011, 13:38
  3. RNS-E mk2 Coding Issues - Help Please!
    By Avus Sportback in forum Satellite Navigation
    Last Post: 27th August 2011, 12:39
  4. Wishbones and ARB issues... Help please!
    By Curt in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2010, 19:35
  5. B5 1.8t running issues! Help PLEASE!
    By s11pyk1234 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th September 2009, 00:12
