Volks AutosSky Insurance
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    S3 uneven front brake pad wear?
    Hi
    I noticed that my N/S front pads have twice as much meat left on them compared to the O/S. The O/S looks as if they'll need replacing very soon.
    Is it common for them to wear unevenly? Or could I have a sticky calliper?
    I've never noticed the car pulling to one side under braking and the discs look to be worn evenly.
    A set of DS2500 are on my shopping list ...
    Cheers, Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Feb 2012
    722
    i had this recently. i suspected a sticky piston so i have stripped the calipers down to refurb. any uneven wear on the discs? what pads are they also. mine were mintex which dont get a great review tbh so mabye poor pads? im sure my caliper was sticking though as the near side used to be so hot compared to the off side. you could literally feel the heat difference getting out the car. daz
    Feb 2012
    722
    just spotted you mentioned the discs lol. checked both sides of the discs?the inside of mine was glazed and the outsides were fine. daz
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by daz-20vt View Post
    Cheers.
    Both the O/S pads were similarly worn down i.e. similar amount of friction material, N/S pads were equal too obviously with more material left.
    I'll have a proper check of the discs, I haven't measured them accurately yet.
    Liam
  1. Front brake pad wear sensor lead?
    By rockape in forum A3/S/RS Parts
    Last Post: 6th December 2011, 13:14
  2. front brake pad wear-indicator wires!
    By imported_tractorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2005, 09:55
  3. front brake pads
    By tboy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd December 2004, 15:11
  4. Uneven Brake pad wear
    By cbass in forum General Technical / How To
    Last Post: 24th August 2004, 22:05
  5. Front brake pads
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2003, 16:30
