Volks AutosAH Fabrications
    Jun 2012
    45
    S3 pressure test
    Has anyone got a definitive guide on how to pressure test an audi s3 for boost leaks? Tried researching it but can't find anything definitive as don't want to blow my turbo seals or anything?
    My intercooler to boost charge pipe popped off and since I put it back on I have lost a lot of power i thought this might be another boost leak unless anyone else has got any ideas as to what it might be?
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    825
    Add Vex182 on Facebook
    Did you check for fault codes? Might help if they were reset.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Jun 2012
    45
    Checked for fault codes on vagcom haven't got any up.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Normally use a 'pressure' test between the top hoses on the S3 so the one coming off the charge pipe and the throttle body... this can be used to test how secure the system is across the SMIC's or FMIC if you have one and normally tested to pressures just over 1.5bar... the kit I use is something Bill made consisting of a bung with a airline fitting and another bung to seal the other end...
    Trickier to do on K03 turbo'd cars as the pipework is different and more awkward to do but the smoke test kit Bill has finds pretty much any leak tbh...
    You can't use a high pressure tester on the complete inlet system though (smoke tester runs to around 0.5psi) as you can blow seals and stuff plus its difficult to keep the pressure up anyway as by design it will always leak making it trickier to track down an actual leak...
    <tuffty/>
  1. Pressure testing boost system?
    By Speedy Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2009, 18:08
  2. Inlet Pressure Testing
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th September 2008, 08:30
  3. Fuel pressure test
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2008, 13:39
  4. Pressure Testing Turbo Hoses.
    By jm-baker in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2007, 19:30
  5. pressure test and surging
    By mac1403 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th November 2006, 20:36
