Sky InsuranceEM Tuning
Results 1 to 8 of 8
    Feb 2013
    Melbourne, Australia
    7
    Exclamation 1998 A3 8l Auto gearbox change to neutral with it self??! help
    Hi every one,
    My first post
    I have 1998 A3 8L AGN, when drive at morning and stop on traffic signal the gearbox change from drive to Neutral mode or it go to no gear by it self, even if I don't touch the shifter it keep changing from (D to N and N to D). I have to give more fuel to make it drive normally, after 10 minute driving the car get normal just like nothing happened before??!
    I scanned the car with vag-com but it give me no fault on transmission at all the only fault I got is: 00515 - Camshaft Position (Hall) Sensor (G40)30-00- Open or Short to B+
    Do you think it can be the reason??
    Feb 2013
    7
    Any one please??
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    823
    Add Vex182 on Facebook
    Perhaps the car knows there is a problem with the sensor and has decided to take it out of gear to sae itself. I would get the sensor sorted anyway - it needs doing even if its not the cause.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Vex182's Avatar
    Apr 2012
    Hinckley
    823
    Also has the oil been changed in it recently? I know on other autos, low oil can cause shifting issues.
    Feb 2013
    7
    Haha do you think the car can think about such things?? I plan to service the car next week and I will see then.
    thanks for your advise, but if any one heard about such problem please advise.
    cheers
    Vex182's Avatar
    Apr 2012
    Hinckley
    823
    Cars can cut power when there's a problem and the ESP can apply the brakes automaticity so it's a possibility that it can.
    Setting the Standard
    Feb 2013
    Cape Town
    90% of the time its, the valve body thats the problem, i have the same car as you a 2000 agn and twice i've had major gearbox issues, replaced the valve body, cleared the error codes with vag and the car drives perfectly afterwards.
    Audi A3 8l 1.8 (AGN) (Pre Facelift) Auto
    Feb 2013
    7
    I don't think it's the valve body, otherwise I will get error codes.
  1. auto gearbox oil change on 3.0 tdi quattro
    By .Jas. in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th June 2012, 14:11
  2. C6 avant auto gearbox oil change
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th May 2011, 22:03
  3. Auto Gearbox oil change at 70K ? / DIY methods
    By RogerTDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd October 2006, 08:54
  4. Fault with auto gearbox on 1.8 sport
    By imported_forteeneight in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2004, 14:26
  5. DSG auto gearbox... confirmed?
    By jamesa in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2003, 14:21
