Volks AutosBadger5
Results 1 to 14 of 14
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Coil pack loom replaced ... so smooth now!!
    Hi
    I finally got around to splicing in a replacement coil pack loom.
    Amazing how much difference it does make, the engine and throttle response seems much smoother now.
    I found my old one was pretty knackered once I'd removed the insulating tape. It's really scary making that first cut into the loom but glad I plucked up the balls to do it.
    While doing this I noticed my tensioner gasket is leaking ... Dammit I only replaced it last year, another job back on the list.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    phil miller's Avatar
    Sep 2012
    Devon
    843
    This is a job ive gotta do ive got 4 new connectors so its just a case of making the loom, not a massive job just not one i really wanna do
    ​Wish Rachel would let me have my TDI mk5 back
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by phil miller View Post
    ah I got the standard replacement loom from TPS and just cut off all the useless crap and spliced it in. For 25 quid you've got all the correct gauges of wire and the connectors are professionally terminated. Just a matter of matching the wires, cutting, soldering and heat shrinking.
    For the S3 none of the off the shelf looms match colouring or configuration so a bit of thinking and butchering is required. If there was a correct loom available I'd have re wired it all the way back to the ECU.
    The new loom had 1 solid-brown coming from the connectors but my existing loom had three separate browns so I had to splice them all together. It ended up tidy enough but just meant I had to triple check connections before cutting and splicing.
    Sep 2012
    Devon
    843
    Tps sell a replacement part of loom for £25? Awesome do you have the part number and is it like the four plugs and 6inches of wire? Is it for an S3 or A3? Need info so I can order one ASAP
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Awesome GTI have one, they have it marketed as an ECS product.
    ECS Tuning Coilpack Wiring Loom Replacement
    There are two version of the loom, one has oil sensor wiring and the other doesn't.
    It doesn't matter what one you get as you'll strip out the non-coil pack plugs/wires and cut the whole thing in half.
    From the dealer or TPS the part should be 1J0 971 658 M (oil sensor) or 1J0 971 658 L (no oil sensor)
    awesome gti coil pack looms on an s3?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,274
    I bet most of the cars on this forum have a badly cracked loom. It really does make a big difference once swapped over.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Eddie S3's Avatar
    Jul 2011
    Aberdeen
    108
    Just bought one from Awesome thanks to this thread. Have been putting it off for months and month and then totally forgot about it
    2002 Audi S3 261bhp
    Miltec Exhaust, Badger5 TIP, Stage 1 Remap, 007P DV.
    Todo: Fit LCR Splitter, FMIC, Clean.
    Sep 2012
    Devon
    843
    Quote Originally Posted by Westy View Post
    Mine are cracked really badly, and lets face it, that wont get any better will call TPS tomorrow and see if they do it, if not i will get one from the top link, that really is spot on
    Thanks lads
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Is it easily visible or do you have to rip it all apart to see it? I'd go out and check but the cars about 4,000 miles away at present...
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by Sam_ View Post
    If you can get to the coil pack connectors it's easy. You'll usually see the insulation cracked.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    This is what mine looked like:
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    Does anyone do a replacement loom for a AGU or am I going to have to make one
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by A3-Lee View Post
    I've googled and can't find any one doing these.
    I think your only option is to buy 4 of the connectors (4D0 906 232) and make your own loom up. Make sure you match the gauges of wire and that you terminate the crimp terminals well. Fortunately you only have three wires on each plug.
    Aug 2010
    bradford
    1,252
    Mine is too got to sort this ha
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
  1. Agu coil pack loom replacement
    By A3-Lee in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2012, 12:48
  2. awesome gti coil pack looms on an s3?
    By slowcoach3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2012, 00:14
  3. Anyone got the part number for the coil pack loom heat shield cover?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd October 2011, 01:03
  4. New coil packs loom from where
    By SiGainey in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2011, 16:49
  5. Coil pack loom
    Last Post: 10th November 2010, 23:36
