Volks AutosBadger5
Results 1 to 16 of 16
    Mar 2011
    24
    Audi A3 Temp Sensor Issue
    Audi a3 1997 AKL engine, 1.6
    Temp sensor in car sits at bottom left (60 Deg) when driving but when you leave the car to idle it goes upto middle (90 Deg).
    This is a blue sensor 4 pin blue,
    Fan comes on when it gets to hot and all pipes feel warm,
    I have bled the system for air in the coolant.
    No over heating issues, Not fault codes apart from the knock sensor.
    Any ideas?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Thermostat....
    <tuffty/>
    Mar 2011
    24
    Its not overheating tho,
    The thermostate only opens and closes when hot or cold - if it breaks then it usually overheats the engine as it gets stuck in one place.
    This is what I think unless a mechanic may know diff?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    A dodgy thermostat normally sticks open not closed... the stat helps regulate flow through the radiator as well as blocking flow while the engine warms up...
    Have you changed the sensor? its fairly common for both the stat and the sensor to fail.... if you have access to VCDS its probably worth checking the temp on both the engine module and the instruments module as the CTS two sensors feed these and its not uncommon for one of the sensors to be faulty and the other to be fine... but your issue sounds more like a dodgy stat...
    <tuffty/>
    Mar 2011
    24
    No probs I appreciate your help,
    New Thermostat has been ordered and ill replace it this sat,
    Ill post back with the update,
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Stats are designed to fail in the open position, change it and your problem is gone fit genuine tho
    ​Wish Rachel would let me have my TDI mk5 back
    Mar 2011
    24
    Should be getting the part Thur/Fri - Then fitting on Sat,
    Anything to watch out for? - Seems a pretty simple task from what Ive read.
    Jun 2012
    Essex
    213
    I done mine last Thursday, after suffering exactly the same proble as your self. The only thing to look out for it the brittle plastic dipstick holder, despite knowing the potential issue and being silly careful, I still managed to snap mine.
    Is potentially a 15 minute job to change it, just make sure you have a 10mm socket, a knuckle type connector and patience, lol
    Mar 2011
    24
    Just an update everyone, the thermostat aint coming till Mon-tue now and I am down in Derby for training with my work, I am back on Thur,
    Planning do do the change next weekend now,
    Will keep you posted.
    Blackie_No1's Avatar
    Jul 2010
    Ballyclare, N.Ireland
    24
    Mine was doing the same until I fitted a new thermostat, now running perfect, knuckle joint would defo make it easier, I had to do the bottom bolt with a 10mm spanner, patience wore thin after a while!!
    1994 Audi 80 1.6i
    Mar 2011
    24
    Hi there,
    New thermo fitted, still same problem,
    On idle it goes upto 90 Deg, when out driving it drops down to 60 Deg,
    Tested old Thermo in a cup of boiling water and it opens and closes no problem,
    So that rules the thermo out, plus it has a new temp sensor, only fault code is the knock sensor.
    Any ideas ?????????????
    Mar 2011
    24
    Anyone Lol ?
    HELP PLEASE :D
    Mar 2011
    24
    Does anyone have the wiring diagram for the a3?
    Dec 2006
    barnsley
    1,016
    could be the impeller off the waterpump has failed
    alot of the impellers are simply glued and designed to fail if the bearings in the waterpump fail
    if however the glue has broken down and the impeller has come adrift but the waterpump is still ok
    the car will come upto temperature and the fans will come on to cool it down
    but when driving normally the temperature will go up and down as the cooling effect of the air will cool the exposed parts of the engine
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Mar 2011
    24
    Would this not cause it to overheat?
    as the car sits idle, it goes upto temp no probs and sits at 90 - I turn the blower on in the car and the temp drops down,
    Car never overheats though,
    A broken water pump not cause more issues than what ive got?
    Is there a way to look and see if the propeller is intack?
    Mar 2011
    24
    PLEASE MARK THIS AS SOLVED!
    I GOT SOLD A DODGY THERMOSTAT - NEW ONE FITTED ALL WORKING WELL
    NOW FOR A NEW KNOCK SENSOR AND HOPFULLY ILL BE DONE :D
  1. Replies: 4
    Last Post: 20th June 2012, 09:36
  2. Audi 2.5TDi - Several issues and in need of advice (temp/starting/mpg)
    By DavieMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th December 2010, 04:47
  3. Audi Temp Sensor
    By tonybolony in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2010, 11:45
  4. Cold running issues, Thermostat or temp sensor?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2007, 14:06
  5. S3 Temp Sensors
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2003, 16:53
