Volks AutosChris Nott
Results 1 to 14 of 14
Thread: Airbags fuse ?
    May 2012
    9
    Airbags fuse ?
    Does anyone know where on earth this is?!
    It doesnt appear in the 'normal' place, and I need to temporarily disable all the side airbags (or the whole system)
    Car is the 130 TDI
    Cheers, Danke Schoen !
    DG.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,611
    On the seats ?
    May 2012
    9
    Cheers for the suggestion---its the ones in the side panels i need to disable, ie. windscreen, seat belt tensioner area etc.etc.
    Guess there must be a master fuse somewhere..Hmmm
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,611
    Why do you need to do this ? Disconnecting them will result in warning lights on the dash as why am asking.
    Jun 2011
    Great Melton Norfolk
    1,340
    Disconnect the battery and leave for 1/2 hour.
    May 2012
    9
    Its only temporary to diagnose an obscure problem in an ICE installation.
    Ideally need to disable the whole system .
    May 2012
    9
    Thanks - is there a way to disable without disconnecting battery? Ie. a fuse?
    Because need to check with engine running..
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,611
    You'll need vagcom to reset the warning lights if the engine is running,
    May 2012
    9
    OK sounds not easily possible then. Thanks anyway
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,611
    Quote Originally Posted by dan98 View Post
    Our vcds section has members everywhere Dan so its possible
    with beer tokens
    May 2012
    9
    Ah i see! Kind of a noobie here , cheers
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,611
    No worries,we all started as noobs so nothing new Dan
    Feb 2011
    Leeds
    173
    If you can find someone with VCDS and the correct knowledge the airbags can be disabled whilst you carry out the work then re-enabled once youve done. Have disabled a friends steering wheel airbag so he can fit a momo steering wheel to his show car
    A3 TDi 196 Bhp 340 ft-lb
    The Build Thread
    Darkside Map, PD150 turbo, Allard FMIC, SFS Outlet pipe, Polybushed, Forge Short Shift , LCR Brembos, 17 TT Comps, AP Coilovers, S3 Recaros
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Are the airbags even fused? I'm not so sure seeing as if the fuse blows then the airbags will fail to deploy. The only time they receive current is surely when they're deployed?
    '02 A3 TDI quattro sport
    8L IS DE BEST
  1. airbag fuse
    By tommac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th March 2010, 07:40
  2. Remove airbag
    By goodspeed in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2008, 11:17
  3. Has my Concert blown a fuse ??
    By SteveDickinson in forum In-Car Entertainment
    Last Post: 8th August 2007, 09:16
  4. Passenger Airbag
    By striderman in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2004, 16:47
  5. Dashboard Display Fuse Problem
    By Jag in forum Classic Audi Forum
    Last Post: 4th December 2003, 16:18
