JMB RetrofitsAH Fabrications
Results 1 to 12 of 12
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Exclamation Car Almost Dies !!
    A few weeks ago i was on a nice clear stretch of road so but my foot down. When i got so the end of the road and slowed down the revs were all over the place and and i had to keep revving it up because it looked like the car was going to cut out.
    Today i was on another clear road so though i would test it out again and put my foot down, sure enough as i come to a stop the engine felt like it was going to cut out.
    After driving the car for a few miles it seems to sort itself out.
    Any ideas what's going on ?
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Scanned for faults?
    Sounds like a pipe has split or popped off...
    <tuffty/>
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Scanned for faults?
    <tuffty/>
    Only faults that showed up are:
    16804 - Catalyst System: Bank 1: Efficiency Below Threshold
    P0420 - 35-10 - - - Intermittent
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-10 - - - Intermittent
    But these are old codes that I've had for a while now (the 16804 one shows up once in a blue moon).
    If a hose popped off would the car go back to normal after a few miles of driving at a “normal” speed ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    If a pipe popped off then no... thats normally fairly permanent.. if a pipe had split then it could have been adapted out by the ECU... smoke test next... the 17705 may be the result of these.... its a leak based code... its also a software bug and can pop up because of that...
    <tuffty/>
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Thanks mate
    Ill do another search and see if i can find anywhere local with a smoke tester.
    How much do places usually charge for a smoke test?
    Also are those home made pressure testers any good ?
    May 2012
    RETFORD, NOTTS
    1,753
    I was charged £30 for a smoke test locally.
    I have read that home made testers not so good if pumping over 5psi through them, however Darkside were happy to test to around 1bar on my pipes recently (bear in mind turbo blows more than this anyway) to check for leaks.
    smoke tester usually only goes up to 1psi
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    May 2012
    RETFORD, NOTTS
    1,753
    Similar to what was used on my car yes.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Quote Originally Posted by @udi A3 View Post
    I was already posting you you made your post....lol
    Ok ill search around for a garage that can smoke it for me
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    So they do work
    Jan 2013
    27
    hi guys i have a problem with my 1.8 turbo i have just put porformance plus in and k and n oil filter. Them i put tesco 99 % octane fuel and it just died and would take ages turning it over to start is it running to rich? its had a stage1 remap1?
    Any ides to help me cheers
    Jun 2011
    Great Melton Norfolk
    1,348
    What is performance plus? Is the K&N an oil covered filter,if so it could be affecting the MAF sensor. best to just replace with an upgraded panel filter.
  1. Car just died. Oil light!
    By McGart in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd January 2012, 16:28
  2. Help - car just died
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2010, 12:52
  3. Car just died this morning.......
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2009, 23:47
  4. Replies: 3
    Last Post: 20th September 2007, 23:50
  5. a car joke, well almost!!
    By MarkS3 in forum General Chat
    Last Post: 18th February 2005, 12:08
