AH FabricationsBadger5
    ToonRing-G's Avatar
    Audi Virgin
    Jan 2013
    Renfrewshire
    62
    Question daft probably obvious question reguarding badger5 v3
    This is probably obvious, but can i assume that the v3 does away with the need for the billet adapter? i'd been looking through the how to fit guide and obviously that includes the fitting of that, and having received my Badger5 kit today theres nothing there, but as i say, do i assume they no longer require this part as the pipe has been remanufactured to include it in its design?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    The V3 doesn't use the billet adaptor... it fits straight onto the turbo
    <tuffty/>
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    882
    Add Vex182 on Facebook
    The 2.2 version used the billet adapter to make sure the airflow is as smooth as possible into the turbo but this adds £££. The V3 does without it like you say but there is a small stepdown into the turbo so you get like 90% of the gains and save a few quid on the way.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    ToonRing-G's Avatar
    Audi Virgin
    Jan 2013
    Renfrewshire
    62
    thats as i thought! i'll get it fitted soon then, i got so far and then gave up earlier on, ended up with the filter and heatshield on with the original hose, which sounds nice even at that!
    forge 007p is due to arrive tomorrow, and once i get the chance i'll get that on, remove the N(whatever it is) valve, and run my amp live feed, and that gets it all done at once
  1. Newbee and probably annoying questions!!
    By ajax1976 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th October 2012, 08:27
  2. Daft Headlight Bulb Question.
    By A3 Sport in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st September 2011, 18:25
  3. Probably a Daft Question but....
    By taylorc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2009, 13:17
  4. Daft Question??
    By RichWalk in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2005, 14:54
  5. Quick/Daft tyre pressures question?
    By jbw in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2005, 17:27
