JMB RetrofitsAH Fabrications
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By Prawn
Thread: Turbo sound
    Jun 2012
    45
    Turbo sound
    Hi
    Just wondering if this is normal :-
    sounds like I can really hear the turbo spinning/hissing
    I was driving the car in 4th gear hard and at about 5500-6000 rpm with wot I can hear like a hissing sound so I let off the throttle then can hear the hissing/spinning sound which sounds like it slows down as the revs start to drop?
    Tried it again and I noticed that on my liguid gauge that the bhp stopped gaining at 248bhp as the sound came back?
    I really hope this isn't my turbo ****ed I can not hear the sound in any other gears even with wot.
    Any help please?
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,083
    Visit 16Klappe's Instagram Channel
    Turbo/boost leak/could be lots of things.
    First thing to do is get a smoke test done.
    I quite often say I'm going to do things.
    Then never do them.
    Jun 2012
    45
    If it was a boost leak would it not be there all the time ?
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,083
    Quote Originally Posted by Coless3 View Post
    Not always, the positive pressure/boost would be pulling it open at full chat where as the rest of the time it stays sealed.
    A cracked exhaust manifold is another option, although not common on OE manifolds.
    Then never do them.
    Jun 2012
    45
    Would the boost pressure not be the same tho in another gear at wot?
    Jun 2012
    45
    Also I can hear it dump the boost when I let off the throttle but the noise is still there until revs drop
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Check the orange pipe from the turbo to charge pipe...
    Jun 2012
    45
    Any other ideas?
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    The sound you could be hearing could be the turbo blades catching on the inner housing due to knackered bearings... The only explanation I have for the sound being on both wot and over-run... If it was a boost leak it would only be on wot and if the DV is dumping as it should, there will be no air in the system to escape through a leak...
    Ben
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Quote Originally Posted by 16Klappe View Post
    Are you kidding? They're the more likely to crack than the windscreen man especially after a map lol
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Turbo sound
    Jardo shut the fk up! This forum is here to help people. You're hardly helping by telling the OP outright that the only thing he can do is get a smoke test and that you know what's best! Get off your high horse.
    Yes a smoke test will highlight any leaks but people don't want to run off to the nearest garage every time they get a problem. They post on here, we give them a list of things to go and check. He may be able to spot a split hose visually, replace it, fixed, no smoke test involved.
    Why don't you be a bit more understanding instead of just forcing your opinions on everyone!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Eddie S3's Avatar
    Jul 2011
    Aberdeen
    108
    Which hoses do you use if you want to test using a compressor?
    Seen something on Uk-mkvis and they have used a foodcan with an attachment for the compressor and then attached to the MAF
    2002 Audi S3 261bhp
    Miltec Exhaust, Badger5 TIP, Stage 1 Remap, 007P DV.
    Todo: Fit LCR Splitter, FMIC, Clean.
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by Eddie S3 View Post
    That method is usually only used for testing between the charge pipe to the TB and is normally for FMIC leak testing. This won't highlight any of the issues with hoses connected to the inlet manifold, TIP, N75 etc.
    S3 Build Thread
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Any VCDS logs or fault codes? It'd be interesting to see if it's making (or exceeding) requested boost, and indeed what requested boost is.
    Also what model/spec is that car?
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,388
    oh dear, looks like this thread has been moderated after another attack from Jardzilla.....
    Benjiman46 likes this.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I just thought Westy was hearing voices....
  1. HELP!!! SOUNDS LIKE IV GOT A SECOND TURBO??
    By dandos in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2011, 23:40
  2. Police siren sound from turbo - A3 1.9tdi 56
    By hnp in forum General Automotive Chat
    Last Post: 2nd May 2010, 21:41
  3. Does This Sound Like My Turbo's Dying!
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2009, 20:03
  4. a3 130 tdi turbo makes a gurgle sound
    By nick1973 in forum Diesel forum
    Last Post: 17th July 2008, 12:46
  5. strange sounding dump valve A4 1.8 turbo sport
    By philS2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th May 2007, 10:26
