Chris NottEM Tuning
Results 1 to 7 of 7
    quattrokid's Avatar
    Jan 2006
    Ayrshire Scotland U.K
    219
    S3 exhaust onto an A3
    I have been asked if the S3 exhaust I'm taking off would be an upgrade for lesser A3 models please?
    I assume it's a straight swap?
    Ta
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    a3's have ko3 turbos so have a different downpipe and cat (as far as I know) so a direct fit I wouldn't think so. Also, is the a3 a Quattro?
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,319
    S3 cat back will fit A3 quattro with a bumper trim.
    4wd exhausts will not fit a FWD car at all though mate, not ever. different floorpans.
    If you're looking second hand, look for mk4 golf systems also, they fit, and are much more common.
    quattrokid's Avatar
    Jan 2006
    219
    The chap interested said his A3 was a quattro model, he would be having my cat and the catback as well so basically all that's from the downpipe... but may need to modify his bumper to take the twin outlets
    Is this correct?
    Cheers for your replies gents
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,319
    the catback will definitely fit. I wouldn't know about the cat though, perhaps Reesy would be better placed to answer
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Prawn, you know i love you and totally respect you right??#
    Ok the S3 exhaust is not a direct fit on an A3 TQS, for starters if running the standard cats you will have to may a reducer as the S3 system has a bigger ID than the A3 quattro, also on the rear box you have the 2 mounts, these dont line up at all as the S3 box is a good 6ins bigger, to get round this a simple cut and reweld of the mounts is needed
    and yes they sound awesome when fitted
    quattrokid's Avatar
    Jan 2006
    219
    .... ok, would the rear valance need to be changed or cut to accommodate the twin outlets?
    So to cut to the chase, IF this interested chap buys my exhaust he could just take it to a local exhaust fabricator who could modify to suite his floorboard contours and mounting points and make a flange to connect the cat to his downpipe?
    Cheers gents
    Rich
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
  1. Would S3 exhaust fit onto 2.0tfsi
    By BlueSpark in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2011, 21:52
  2. Cabrio exhaust onto non cabrio
    By Martin69 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th May 2011, 12:16
  3. Miltek onto oe exhaust?
    By steviet in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2009, 12:13
  4. 1.8t duel exhaust onto a 1.9tdi
    By Niknak in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th February 2009, 18:23
  5. RS4 exhaust onto an S4?
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2007, 19:03
