Volks AutosMonster Motorsport
    Sep 2012
    71
    Question 8L S3 BAM Brake warning, ESP, ABS and Battery warning light after hard acceleration
    Hi Folks,
    I was driving into work this morning, just thinking to myself; "The S3 is going well, not been to the parts department for months" so I give it some right boot off the last roundabout before my work and the dash lights up like a christmas tree!
    The flashing brake warning sign is on as is the ABS and ESP lights, the battery light came on initially and then went dim.
    I just drove the last half mile to work gingerly and parked up, haven't had time to investigate it yet, but I wondered if anyone else has ever had a similar issue?
    Any advise on fault finding or what it could be?
    Mike
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Check for fault codes in the first instance... if there are warning lights there will be fault codes logged...
    <tuffty/>
    Sep 2012
    71
    Ok,
    I'll get it on VagCOM tonight and see what comes up...
    Sep 2012
    71
    So, I managed to drive home last night after work, all the warning lights have gone out except the battery/battery light (the red one). I suspect a failed alternator.
    The yellow battery light started flashing near the end of my ten mile drive with no lights, heater, radio.
    I tested the battery voltage and it was 12V, when idling it was 12.6V; would a healthy alternator not usually be between 13 and 14V?
    I've not had a chance to log the fault codes as the pc is on the blink too. should get logs on Friday hopefully.
    Sep 2012
    71
    alternator replaced today and that has fixed the issue.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    819
    Add Vex182 on Facebook
    Think mine is 14.4 at the battery with my alternator. If yours was 12.x then it must have been just enough to charge the battery and nothing more.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
  1. ABS AND TRIANGLE WARNING LIGHTS
    By blanc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th October 2011, 14:41
  2. ESP, ABS and now Power steering warning
    By r10jdl in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th August 2011, 17:20
  3. ABS and Tracion control light on all the time.
    By myke in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2010, 02:24
  4. ABS and traction control light
    By joshwalters123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2009, 18:47
  5. ESP and Battery Warning Lights
    By djcormie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th May 2009, 14:46
Tags for this Thread
