EM TuningAH Fabrications
Results 1 to 9 of 9
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    TT Springs on an S3 ?
    Is anyone aware of the differences i believe they are different part numbers for 1.8 quattro models, my S3 has 5dot pink or violet rear springs & have seen these also available for the TT.
    Regards
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    The TT does have a few variations on springs, the quattro sport had different springs, the s line was a differnet spring too, i think if you order 18 inc alloys it came with slightly lower suspension too so a different spring again. Theres nothing to stop you from using tt quattro springs on the S3 though and if you check on vagcat you'll probably find they share some of the springs listed.
    A quick look on vag cat shows the TT and S3 share the following rear springs:
    Part No.s and paint marks -
    1J0511115CR 5 marks violet
    1J0511115DD 2 marks silver
    1J0511115DE 3 marks silver
    8N0511115E 1 mark red - this is also noted as for sports type running gear under the TT which might be the sline or quattro suspension
    The following was also listed for the S3:
    1J0511115BM 5 marks blue
    The following was also listed for the TT:
    8N0511115F 2 marks red for sports type running gear
    8N0511115G 3 marks red for sports type running gear
    1J0511115DF 4 marks silver
    Nov 2005
    UK
    1,689
    I take it you dont know the different characteristics of each spring ?
    wanted for 8L S3:
    Milltek system
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Mine had the 18" RSTT's from the factory as an option and my rear springs are: 1J0511115DE with three silver dots if that helps.
    Nov 2005
    UK
    1,689
    Do you know this for sure ?
    wanted for 8L S3:
    Milltek system
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Not sure if your post is directed at me but yes I am 100% certain. I had the springs fitted and I checked my invoice for the part number. I wanted to make sure I had the right springs fitted because mine had the wheels as an option and therefore the slightly lowered suspension was fitted. There is a code for the lowered suspension on a sticker in the tyre well of your boot (which basically tells you the options your car comes had fitted from the factory).
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    P.s the springs I am talking about for my car were rear springs. The front ones are different and have pink dots on them
    Nov 2005
    UK
    1,689
    I'm also talking about the rear springs. I've recently fitted a set & its sitting real high. Started to wonder if it wont settle I'll have to source different springs
    wanted for 8L S3:
    Milltek system
    Nov 2005
    UK
    1,689
    just fitted some 2 red dot TT springs to the S3 the gap has closed (2 fingers), it looks good
    wanted for 8L S3:
    Milltek system
  1. Best Shocks That Match H&R Springs
    By XXX_18T in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2003, 22:38
  2. FAO 50mm H&R springs
    By V1RDE in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2003, 13:08
  3. What lowering springs?
    By excursion in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2003, 21:58
  4. Best Match Shocks For H&R Springs
    By XXX_18T in forum TT/TT-S/TT-RS Forum
    Last Post: 29th May 2003, 15:29
  5. Eibach Springs on A3 T Sport
    By paul_b in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2003, 12:18
