Volks AutosMonster Motorsport
    Oct 2012
    South Africa
    268
    Wheel offset query with adapters
    Hi guys,
    In need of some assistance,
    I am purchasing some wheels that are 5x112 pcd so ill be needing adapters.
    The wheels are ET42.
    If I run 25mm adapters upfront = ET17
    If I run 30mm adapters rear = ET12
    Will the wheels sit flush on a S3? Im not looking for poke at all.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Depends on the width of the wheels... for example... I have genuine RSTT 18x8 ET 33 wheels on my S3 and with 10mm (ET23 effective) spacers the fronts fit nicely under the arches.... based on that your ET17 up front will poke out another 6mm
    I run 15mm (ET18 effective) spacers on the rear and they don't quite fill the arch
    <tuffty/>
    Oct 2012
    South Africa
    268
    Thanks Paul, The new wheels are 8J 18"?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Quote Originally Posted by Sidey View Post
    Use the example above mate... can't say for sure where the wheels will end up though...
    18x8 ET33 with 10mm front and 15mm rear spacers look like this on mine...
    <tuffty/>
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    My wheels are 18x8.5J ET25 and i run 10mm spacers on the front and 20mm on the rear. I have a bit of poke front and back but your wheels will sit a further 8.4mm further inside the arches and the rear a further 13.4mm inside the arches compared to mine so should be good
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Oct 2012
    South Africa
    268
    Hopefully I get the wheels this weekend then I can test fit them on Gizmo's adapters on his car.
  1. 8J 18 wheels offset 32 with 235/40R18 tyres - will this be OK on 2010 S3?
    By Braveheart in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2012, 16:20
  2. S Line wheel offset query
    By Lyons in forum Handling
    Last Post: 12th January 2010, 20:43
  3. 19" wheels - offset and size query
    By Light Speed in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th January 2010, 19:48
  4. RS4 rep wheels sizes & offset query?
    By kosmickid in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th October 2008, 19:10
  5. Wheel Offsets and PCD Adapters HELP
    By sitrials in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2007, 11:09
