Volks AutosChris Nott
    Gordie_S3's Avatar
    Feb 2013
    Melbourne, Australia
    72
    idle rumble/ missfiring - can't figure out problem
    My Audi S3 8l AMK engine has been misfiring on idle, and through out the revs.
    I've changed the following...
    - New MAF
    - New air filter
    - 4 brand new ignition coils
    - 4 new spark plugs
    The engine light doesn't come on, and it rumbling on idle...and it sort of hiccups through out the revs. It also back fires a little as I'm down gearing.
    I've noticed the crank case breath hose has a few holes in it, I've order a silicon replacement. Could this be the problem? :/
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Any fault codes?
    <tuffty/>
    Gordie_S3's Avatar
    Feb 2013
    72
    No codes.
    Ended up fixing the problem just then.
    It was the hose(vacuum hose?) coming of the fuel pressure regulator, it was split and cracked! Replaced it and the car is running fine.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Ouch!... going lean potentially... good job you spotted it
    <tuffty/>
    Gordie_S3's Avatar
    Feb 2013
    72
    <tuffty/>
    The car is running ALOT better on idle and throughout the revs, but I am noticing slight back firing when I'm gearing down...does that mean its still running bit lean? What else could be the issue?
  1. Replies: 4
    Last Post: 4th August 2013, 19:52
  2. High pitched whistle. Can't figure it out
    By Pipsqueak in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd July 2012, 21:45
  3. 97 (P) URS6 with overboost /cutting out problem
    By smogthemog in forum General Technical / How To
    Last Post: 30th October 2006, 20:06
  4. Cutting out problems, any advice?
    By imported_smoke in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th December 2005, 18:16
