Monster MotorsportVolks Autos
Results 1 to 7 of 7
    Yohan87's Avatar
    May 2011
    404
    Fooling AC Pressure Switch / Coding out brake pad wear indicator
    Evening,
    Ripped the AC system out my car at Christmas and the Climate Control display has started flashing tonight. Not Vag-Com'd it yet but I assume it's because it has just cottoned on to the fact that the AC pressure is low.
    Can the pressure switch be linked out with a resistor or even better, coded out?
    Secondly, I linked out my brake pad wear indicator over a year ago but tonight the light popped back on. Presumably the link has come loose.
    Can this be turned off via VCDS or do I need to stop being lazy, take the wheel off, and solder the wires together?
    Yohan87's Avatar
    May 2011
    404
    Ok looks like this may do the trick for the brake wear indicator.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    With low AC pressure it just will not keep the symbol on, IE if you press it, it comes up then straight off again, did you take the pump off? it may be unhappy there is no signal to the clutch?
    Yohan87's Avatar
    May 2011
    404
    Yeah I removed the whole system.
    It might not be low pressure, haven't scanned it yet. But from what I've read it seems the flashing climate displays means a climate related fault code and I just took a guess at that since I have removed the system.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,160
    With the brake wear sensor, just cut it off and twist the wires together and tape them up, done.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Yohan87's Avatar
    May 2011
    404
    Quote Originally Posted by Westy View Post
    I did mate years ago but I think it's come loose. Being lazy it's easier to power up my netbook than take a wheel off
    Westy's Avatar
    Dec 2008
    17,160
    Quote Originally Posted by Yohan87 View Post
    Lazy sod. Get the tools out
    S3 Build Thread
  1. Brake pad wear indicator
    By jdp1962 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st April 2010, 11:17
  2. Replies: 15
    Last Post: 27th May 2008, 20:41
  3. Brake pad wear
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd February 2007, 07:10
  4. front brake pad wear-indicator wires!
    By imported_tractorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2005, 09:55
  5. Uneven Brake pad wear
    By cbass in forum General Technical / How To
    Last Post: 24th August 2004, 22:05
