EM TuningJMB Retrofits
Results 1 to 18 of 18
    Feb 2013
    Relentless dp sports cat.. Slight dissapointment?Xs power dp an sports cat
    Right just few little problems i found after fitting mine yesterday.... Anyone else feel the same?
    The bracket which is ment to mount to subframe mount is hard against the subframe.
    Only option is to cut it off a realign!
    Secondly why pay out for a nice 3" system when it has that silly reducer to fit a standard system?
    It was like a cock in a sock.... So i had to weld another bit of pipe on so it fitted my miltek cat back. Which surely must be restricted? 3" dp an sports cat which then drops down to 2 1/2? 2 3/4". Then back to 3".
    Third an final fault is it hangs low under the car so it now scraps over speed bumps :'(
    Rant over. Lol.
    Other than that its a nice looking bit of kit and build quality is really nice. :-)
    Whats your thoughts?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    Sadly its fairly typical of Relentless's wandering quality control... shame... the are better than they were to be fair but I guess one or two slip through..
    The reducer is realistically to allow it to fit to the std system.... you can see why they did it... its difficult to cater for every aftermarket setup out there so the easiest way is to make it fit a std system...
    Have heard a few peeps suggest the lower bracket can be problematic...
    <tuffty/>
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Mine fits like a glove... You sure you've done it right? :/
    Also, unless you're running 400bhp+ you really don't need more than 2.5" cat-back. The 3" downpipe frees up the turbo, lets it spool faster initially, but the difference between 2.5" and 3" cat backs (bearing in mind how restrictive cats are...) on even a stage 2 car is not noticeable. I got the decat version so I don't have that problem
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Feb 2013
    Im happy with it overall just need to get it on the ramp an sort the bracket out. I may modify the pipe in future but if its not restricting the horses then its happy days. .
    Ill try an get a picture of how it hangs under the car, its like the angle is wrong off the flexi it goes downhill the back up. Strange.
    Thanks guys
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Feb 2012
    bedfordshire
    737
    I have got to adjust mine aswell as it sits low to and sometimes catches, but apart from that mine fitted ok
    Feb 2013
    I can look at pictures? Is it cause im a newbie? I just get a box with a question mark in it.
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    You should be able to... Here try this;
    Feb 2013
    I can see
    Yea mine looks the same as yours. Must be ok then.
    Thanks!
    Bleachy....
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    they do sit very low on the decat section.
    They seem to have a bend in there that I don't think is needed, mine sat very low like that and scraped everywhere, so I removed the decat section, and cut out the bend and replaced it with straight 3'' pipe and it sits much further up.
    Whether this would cause prop clearance issues with an S3 I'm not sure, worked a treat for me though.
    My front hanger also didn't line up at all.
    Feb 2013
    Prawn
    Thats probably what ill end up doing mate. Its got a 2 or 3" gap between the exhaust an heat shields. Dont no how this could be missed? Lol.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,318
    I assumed that it was to clear the prop on the S3, but perhaps not!
    Feb 2013
    No theres loads of room under there. Ive got to get it on the ramp to sort the dp mount out so ill get some pics.
    Ive just bought haldex oil an filter an inner an outer cv boots front an back as im going through the whole car, new mounts bushes etc. Got my work cut out here lol.
    Aug 2010
    bradford
    1,252
    mine vibrates on the prop shaft and sits very low need to sort it well anoying
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    Feb 2013
    Mines started rattling on the subframe...
    Feb 2013
    30
    Hi my relentless downpipe and sport cat has just arrived. Any advice when fitting it and problems that occurred that you could warn me of. Ha
    Sep 2010
    Devon
    756
    Having spent two solid days fitting the damn thing my only advice is make sure you have a very good tool kit, a 4" angle grinder, preferably an air chiesel, preferably a ramp a whole lot of patience and ingenuity and a good mate. Loads of guides around, drop the subframe, undo prop shaft gain access through osf wheel arch etc. And don't bother if your in a hurry, ill equiped, have no patience or its your first mod
    For the record mine fits like a glove and the ceramic coating means even after a hard run its still cool to the touch unlike the catback lol!!
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    S3Zek's Avatar
    Sep 2011
    407
    Quote Originally Posted by slowcoach3 View Post
    where did you get your ceramic coating done mate? im thinking of doing my mani and down pipe...could you drop me a pm where and how much to if you dont mind? cheers
  1. A4 Quattro 1.8 T sport 2001 juddering/loss of power
    By chocolatedobe in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th February 2011, 16:47
  2. XS Power Down pipe and cat modifications
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2010, 10:58
  3. Help / Advice needed, A3 1.8T, Power blipping /slight loss of power
    By Lex007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2009, 09:49
  4. slight loss in power....
    By J45SON in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th January 2008, 14:22
  5. Replies: 0
    Last Post: 13th March 2005, 11:52
