Sky InsuranceAH Fabrications
Results 1 to 10 of 10
    Gordie_S3's Avatar
    Feb 2013
    Melbourne, Australia
    78
    Smoke from engine bay?
    Hey everyone, new to the forum! I drive a 2001 Audi S3 8L, engine code AMK...112xxxkm
    I've noticed today once the engine gets hot, abit of smoke starts coming up from the back of the engine? Its coming up with the piping coming of the turbo.
    What could be the issue?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    is it burning oil ?
    Gordie_S3's Avatar
    Feb 2013
    78
    Yeah it is, it goes away soon after engine is turned off.
    Gordie_S3's Avatar
    Feb 2013
    78
    And it only occurs when I drive it a little harder the usual :/
    bez101's Avatar
    Jul 2008
    8,491
    you may have got a leaky cam cover seal
    droping bits of oil onto the exhaust and burning off
    check down the back see if you can see any oil on the engine.
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    turbo oil feed/return hoses?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    538
    could also be the rubber elbow hose connected to the metal charge pipe - it's wrapped in heat shileding behind the engine. I had exactly the same symptoms as you and it was that pipe for me that was split
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Leaking cam cover gasket, been their done that, thought the car was on fire down the m1, was oil dripping from the leak onto the exhaust mani.
    Gordie_S3's Avatar
    Feb 2013
    78
    Thanks guys!
    mark_S3's Avatar
    Yorkshire & Humber Events Rep
    Sep 2012
    Wakefield
    600
    Sounds like I have the same problem..... Cant really see much but there is some oil staining on the exhaust manifold from what I can see.
    Presume you sorted the problem? If so was it the cam cover seal?
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SPS Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, JR Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes * TFSI Coilpacks * Saikuo Michi S3-OCC *
    * PowerFlex Rear Engine Mount Bushes *
    [IMG][/IMG]
  1. Ticking from engine bay
    By Blounter in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2011, 16:48
  2. Rattle from Engine Bay
    By jb0o in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th December 2009, 20:29
  3. Hissing from engine bay when car switched off..
    By Dans-first-Audi in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2008, 15:11
  4. Noise from engine bay of TDI...
    By Bigman in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2007, 21:22
  5. Burning smell from engine bay a3 1.8T
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2005, 20:05
