EM TuningChris Nott
Results 1 to 10 of 10
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Gear box oil change
    As said in the title, I'm thinking I'm in need of gear box oil change, as I don't think it's ever been done. I did search the forums for specs etc on a 1.8t '98 AGU, however came to no avail.
    Does anyone know the spec's (oil grade etc.) and how-to's?
    Also, whilst posting, I have a few other questions..
    1) When I change gear, I get a kinda of lumpy jerk? Not sure what that easy, maybe clutch problems?
    2) Plugged into Vagcom last night and came up with the following codes:
    16514 Oxygen (Lamba)
    Sensor B1 S1:
    Malfunction in Circuit : P0130
    01312
    Powertrain Data Bus
    Sporadic - defective
    Could anyone shed any light on these?
    Cheers,
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,017
    This has been discussed a few times mate... search can be a little iffy but maybe worth trying to be a little less specific with the criteria as the info is not that specific to any one car..
    Anyhoo... its 75W90 semi synth gear oil GL4 spec (not GL5)... not sure of the capacity off hand (2.5ltrs rings a bell) so 3ltrs should be enough...
    <tuffty/>
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,280
    Gearbox oil??
    Maybe have a read through this post. x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,017
    Quote Originally Posted by Spatula View Post
    Sensor B1 S1:
    01312
    Powertrain Data Bus
    Cheers,
    Jumpiness could be an engine mount or dogbone...
    Check your codes here..
    Category:Fault Codes - Ross-Tech Wiki
    ...but sounds like the lambda sensor is faulty and this could also be contributing to your jerky gear changes...
    <tuffty/>
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Thanks for the info guys and gals. I do try and search for related topics before I post, because I'm aware that you've probably answered a lot of the questions that pop in these threads a million times!
    @ <tuffty/> - noted on the be less specific the search function works a bit better.
    I found bit's a bobs related to gear oil stuff, however they were all for different models, and I assume oil type/amount changes model to model.
    Quick question, may sound pretty dumb.
    What is the lambda's function?
    Also, what is the Haldex's function? - sorry to be so nooby!
    Thanks guys
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    819
    Add Vex182 on Facebook
    The haldex enagages and disengages the rear wheel drive. It connects when slip at the front wheel is detected, think of it as a clutch. The lambda sensors monitor the exhaust gases and the response by them make the Ecu adjust the air and fuel mixture.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Also, and sorry about this.. lol
    I get the Lambda sensor needs replacing, but 01312
    Possible Solutions
    • Check Databus Wiring and/or Connector
    How would one go about this task?
    Cheers,
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Quote Originally Posted by Vex182 View Post
    Ah ok! This makes sense.
    My A3 is FWD. I assume this means I don't own a Haldex..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,017
    Thanks guys
    Lambda controls fuelling... in your case you have a narrow band lambda and only controls fuelling on idle and cruise.. when afr goes less than lambda 1 (normally under acceleration etc) then lambda goes open loop and fuelling is 'calculated' from airflow
    Haldex is a electronically controlled clutch system that is used on AWD systems to engage drive to the rear wheels
    <tuffty/>
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Ok I understand. This will probably explain my lumpy idle too...
    So how do I check data bus wiring and/or connector?
    (regarding the other code)
  1. Gear box oil change
    By bubba..dubba in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2013, 15:23
  2. gear box oil - does it need changing?
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2010, 13:02
  3. Gear box oil.
    By nickelvery in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2007, 23:08
  4. Gear box oil
    By starski4578 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2005, 10:17
  5. Gear box oil
    By duane in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2005, 21:07
