Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By beachbuggy
Thread: Audi S3 APY VCDS logs with remap
    Aug 2012
    Bulgaria
    32
    Hi people,
    this is my logs of my Audi S3 APY 2000 with remap from Madness Motorsport Bulgaria
    what you think?
    this is at 3-gear from low RPM to 7000 RPM
    [0] Marker [1] TIME STAMP [2] Engine Speed (G28) /min [3] Mass Air Flow Sensor (G70) g/s [4] Throttle Valve Angle % [5] Ignition Timing Angle °BTDC [6] TIME STAMP [7] Engine Load (specified) % [8] Engine Load (spec. corrected) % [9] Engine Load (actual Value) % [10] Boost Pressure Control (N75) % [11] TIME STAMP [12] Engine Speed (G28) /min [13] Engine Load % [14] Boost Pressure (specified) mbar [15] Boost Pressure (actual) mbar
    0.30 1520 12.00 7.8 27.0 0.59 115.0 113.4 41.4 0.0 0.01 1520 30.8 970.0 1010.0
    1.19 1600 22.36 17.6 24.8 1.48 118.8 117.9 75.9 95.3 0.89 1560 42.1 970.0 1010.0
    2.08 1800 31.47 81.2 19.5 2.39 131.6 129.9 91.7 95.3 1.79 1720 82.0 1530.0 1070.0
    2.98 2080 44.78 89.0 16.5 3.28 154.9 152.2 116.5 95.3 2.68 2000 98.5 1820.0 1250.0
    3.89 2480 76.61 96.1 12.0 4.19 175.9 173.1 167.7 83.5 3.58 2320 130.1 2030.0 1530.0
    4.79 3040 131.61 100.0 10.5 5.09 189.5 186.6 191.7 73.7 4.48 2800 191.7 2220.0 2180.0
    5.69 3760 162.25 100.0 11.3 5.99 191.7 189.6 191.7 72.9 5.38 3520 191.7 2310.0 2540.0
    6.59 4480 181.00 100.0 11.3 6.89 189.5 186.6 191.7 73.3 6.29 4280 191.7 2260.0 2540.0
    7.49 5080 188.50 100.0 10.5 7.79 185.7 183.6 191.0 74.1 7.19 4880 191.7 2180.0 2430.0
    8.39 5680 194.58 99.6 15.8 8.69 180.5 176.1 177.4 77.6 8.09 5440 187.2 2120.0 2270.0
    9.29 6080 198.92 100.0 18.0 9.59 176.7 174.6 182.0 78.8 8.99 5920 174.4 2010.0 2220.0
    10.19 6440 197.36 100.0 18.0 10.49 175.2 173.1 178.9 79.2 9.89 6320 179.7 2040.0 2190.0
    11.09 6760 196.78 100.0 18.8 11.39 173.7 171.6 177.4 78.8 10.79 6680 178.2 2010.0 2180.0
    11.99 7040 195.81 99.6 12.8 12.29 173.7 171.6 125.6 0.0 11.69 6960 174.4 2010.0 2160.0
    12.89 6880 9.78 3.9 20.3 13.19 173.7 171.6 6.0 0.0 12.59 7080 66.9 970.0 2280.0
    this is at 4-th gear from low RPM
    0.60 1720 25.47 36.5 24.0 0.01 119.5 117.9 39.8 0.0 0.30 1680 61.7 1190.0 1010.0
    1.50 1840 33.39 82.7 18.8 0.90 123.3 122.4 81.2 95.3 1.20 1800 85.7 1690.0 1130.0
    2.39 2000 42.58 87.8 16.5 1.79 131.6 129.9 95.5 95.3 2.10 1960 99.2 1820.0 1290.0
    3.29 2200 55.03 91.4 14.3 2.69 143.6 141.8 110.5 95.3 2.99 2120 117.3 1960.0 1480.0
    4.20 2480 83.61 95.7 9.8 3.60 160.2 156.7 136.1 89.4 3.90 2360 150.4 2070.0 1780.0
    5.09 2840 116.86 98.8 7.5 4.50 174.4 171.6 176.7 75.7 4.80 2720 191.7 2220.0 2340.0
    5.99 3240 136.31 100.0 10.5 5.39 184.2 180.6 191.7 72.9 5.70 3080 191.7 2300.0 2540.0
    6.90 3640 156.31 100.0 6.8 6.30 190.2 186.6 191.7 72.9 6.59 3520 191.7 2320.0 2540.0
    7.80 4040 166.89 100.0 6.8 7.19 191.7 189.6 191.7 72.9 7.50 3920 191.7 2290.0 2540.0
    8.70 4440 178.64 100.0 6.8 8.10 191.7 186.6 191.7 72.2 8.40 4280 191.7 2230.0 2540.0
    9.60 4760 181.50 100.0 10.5 9.00 191.0 185.1 191.7 72.2 9.30 4640 191.7 2190.0 2500.0
    10.50 5040 183.78 100.0 8.3 9.90 188.7 182.1 191.7 71.8 10.20 4920 191.7 2150.0 2420.0
    11.40 5280 177.83 44.3 9.0 10.80 186.5 171.6 191.7 71.0 11.10 5200 178.2 2010.0 2450.0
    12.30 5520 157.31 41.2 14.3 11.70 185.0 173.1 168.4 65.1 12.00 5440 159.4 2020.0 2290.0
    13.20 5680 153.83 38.4 12.8 12.60 182.7 167.2 147.4 66.3 12.90 5640 156.4 1940.0 2130.0
    14.10 5840 142.06 36.5 18.8 13.50 181.2 159.7 149.6 63.1 13.80 5800 148.1 1850.0 2080.0
    15.00 6000 180.58 38.8 14.3 14.40 178.9 152.2 142.9 65.5 14.70 5920 151.9 1870.0 2080.0
    15.90 6200 160.22 35.7 15.8 15.30 178.2 152.2 157.9 72.2 15.60 6120 156.4 1780.0 2470.0
    16.80 6280 132.92 34.9 21.0 16.20 176.7 146.3 139.8 62.0 16.50 6240 132.3 1730.0 1990.0
    17.70 6360 139.83 40.8 17.3 17.10 176.7 143.3 123.3 62.4 17.40 6320 122.6 1700.0 1850.0
    18.60 6480 193.33 100.0 16.5 18.00 175.9 153.7 150.4 80.8 18.30 6440 171.4 1840.0 2110.0
    19.50 6640 186.31 100.0 14.3 18.90 175.2 150.7 172.2 72.2 19.20 6600 171.4 1810.0 2120.0
    20.39 6760 181.31 100.0 17.3 19.80 173.7 150.7 169.2 71.8 20.09 6720 169.2 1800.0 2080.0
    21.29 6880 191.44 27.5 7.5 21.59 173.7 164.2 7.5 0.0 21.00 6840 163.9 1950.0 2020.0
    Audi S3 8L 2000 APY | Madness Motorsport Software 246 h.p. | deCat | 13.8 @ 1/4 mile |
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Airflow seems low, actual boost seems way over request and don't ever seem to be on full load beyond 5k rpm... massive over boost around 4k rpm
    <tuffty/>
    beachbuggy's Avatar
    Surrey
    1,745
    Quote Originally Posted by devil_vas View Post
    Hi people,
    what you think?
    let alone the throttle closing at 5280rpm! That's a sign its not a good map! Over boost and throttle close to protect engine. Needs sorting asap
    Pedrosousa likes this.
    RIP S3dave
    May 2004
    nr Glos
    7,175
    good spot dan
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Aug 2012
    Bulgaria
    32
    thank you for the atention guys
    actually my car do some correction, because overboosting. i think, may be the problem is air fuel ratio. in this rpm with overboosting, probably is "poor". is this big difference between "specified" and "actual" and is this reason for worry?
    with this soft i have 13.8 @ 1/4 mile and run over 10k miles. never cut off the boost or any problem with the soft! max speed with full throttle 260 km/h
    RIP S3dave
    May 2004
    nr Glos
    7,175
    and your throttle is closing on the log you posted
    www.badger5.biz
    bill@badger5.co.uk
    Aug 2012
    Bulgaria
    32
    yes, now i see. "full throttle" is just phrase. i don't know what happen with the car on 5-th and 6-th gear in high rpm.
    what about my guess for
    relationship between "poor" AFR and overboosting.
    next days i will go to the performance garage for little change of my soft.
    RIP S3dave
    May 2004
    nr Glos
    7,175
    i dont see your afr on the logs
    www.badger5.biz
    bill@badger5.co.uk
  1. VCDS is it the same for VW as Audi ? or anyone in cumbria with VCDS
    By brough74 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2011, 12:47
  2. Audi A6 Instrument cluster testing with VCDS
    By Jetcat in forum VCDS (formerly VAG-COM) forum
    Last Post: 20th February 2011, 21:27
  3. Audi 2.5 tdi T reg "99" Problems with remap
    By slick58 in forum Diesel forum
    Last Post: 28th January 2005, 12:31
