Volks AutosChris Nott
Results 1 to 36 of 36
Like Tree4Likes
  • 1 Post By 16Klappe
  • 1 Post By phil miller
  • 2 Post By 16Klappe
Thread: dump valve
    2nd gear sorts em out
    Jan 2013
    preston lancashire
    150
    dump valve
    what is the danger or harm to the engine if your dump valve is fitted to the hotside rather than the cold side ? anybody please cheers
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    The dump valve is on the hot side as standard anyway...
    I quite often say I'm going to do things.
    Then never do them.
    Jan 2013
    preston lancashire
    150
    i fitted a bailys atmospheric dv about 8 months ago and somebody on here the other day told me i had fitted it wrong or maybe im confussed is this the hot side or the cold side PC180025.jpg
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    890
    Add Vex182 on Facebook
    That's fitted to the hot side - as in before the intercooler(s) have a chance to cool the air. Seems a little bit of a odd place to put it, usually on the hot side it is just after the turbo on the hard charge pipe, up at the top where you have blocked off with a red pipe.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,603
    Its a atmospheric valve regardless of hows its fitted so get it binned off for a recirc valve... and while you are at I would refit it to the std position...
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    Jay im not been funny but have you got a t piece between the fpr and the baileys dv? If not your cars going to be running into alot of problems.
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    I've never seen that, well done.
    Then never do them.
    Jan 2013
    preston lancashire
    150
    dani_b19 what does frp mean ?please
    Jan 2013
    preston lancashire
    150
    16Klappe what does well done mean ? good or bad ?
    Oct 2012
    Telford
    95
    I believe hes being sarcastic instead of adding anything of use to your problem
    Avus Silver 2002 S3 BAM purchased Oct 2012
    Work Done To Do
    • Full Service
    • Sump and Pickup Clean
    • Rocker Cover Gasket
    • CV Joint Replaced
    • Top Mounts
    • New Rubber
    • Front stock ARB rear R32 ARB
    • DS Ball Joint
    • Haldex Service
    • Rear wheel arch bodywork
    • B5 Tip
    • Relentless DP and Sportscat
    • Custom Remap
    • RNS-E Install
    • Refurb Alloys
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,234
    Fuel pressure regulator, its the thing on the end of the fuel rail!
    lovemelongtime's Avatar
    Jun 2012
    Horsham
    335
    I think he means fpr - fuel pressure regulator.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,603
    Quote Originally Posted by jay22s3 View Post
    Bad...
    <tuffty/>
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    Quote Originally Posted by Filth View Post
    What he said^^
    I've never seen such a bizzare combination of original boost pipes, wrong dump valve and wrong location.
    You've basically blocked off the right port, fitted the wrong valve and then fitted it to what would be the correct location if you had a K03s and a front mount intercooler.
    Very strange.
    Did you follow pictures on the internet or did somebody do this for you?
    A3-Lee likes this.
    Then never do them.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    A couple of pics to help you out....
    The thing circled in blue is the FPR don think its a good idea to T anything off the same hose.
    From the green circle it looks like a black hose is coming out of a T.
    An idea on what to do with your DV....lol
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Jan 2013
    preston lancashire
    150
    yes there is a t piece between the f p r its just black at the other side its been running like this for ages now i thought the whole thing about dump valves was to get the air out of the system quickly ? so why does it matter if the air has not had chance to cool down before it reaches the intercooler dump valve , dumps the air yes ! its run fine up to now so i think i will just leave it as it is rather than listening to so many different opinions at the end of the day its all personal choice if it goes bang who cares its only an engine but cheers for the advice people
    Jan 2013
    preston lancashire
    150
    i thought that joining this forum would be good but it turns out your all a bunch of dicks who know **** all well not all but most so seeya
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Ill let 16Klappe step in here....lol
    Oct 2012
    Telford
    95
    Have i got time to get some popcorn?
    Work Done To Do
    • Full Service
    • CV Joint Replaced
    • Top Mounts
    • New Rubber
    • DS Ball Joint
    • Haldex Service
    • B5 Tip
    • Custom Remap
    • RNS-E Install
    • Refurb Alloys
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Really???
    Top work, so you join a forum ask a question and then call all the people who try to help dicks!
    I think most people will whole heartedly laugh their socks off if your car does go boom.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,603
    Dump valves are designed to release the pressure when the throttle plate closes as this can lead to turbo damage... while there is nothing fundamentally wrong with where you have put the valve it seems a little bit odd as there is no real advantages here... even the much discussed cold side relocation is not really the best place for a dump valve... the OE position closer to the turbo is the better place but for practical reasons it can be mounted elsewhere (as I have done on mine...)
    The problem with yours is centred around two things... firstly, tapping the vacuum from the FPR feed is not best practice... its very important that the FPR pipework is 'reliable' otherwise there is a risk of the fuelling going lean if its integrity fails...
    Secondly... atmos valves aren't suited to std VAG ECU's... the air entering the charge system is metered via the MAF... the ECU has calculated how much fuel to inject for the correct AFR... venting this air to atmos means the engine runs rich... this can cause misfires, soiling of the plugs promoting multiple misfires and poor running, stalling of the engine etc...
    You posted asking for advice and due to the way you have applied your modifications you got some advice...
    Its your choice at the end of the day but there it is... you will have to excuse Jardo, subtle is not a specialism of his but the advice is sound and correct..
    While you may not care about your engine going bang there are others that will and this forum is not about giving poor advice (although the delivery can vary )
    <tuffty/>
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    You've asked what the danger or harm is of mounting the DV in the hotside (which is the standard location as VAG intended), we've told you there is no problem and that actually you have some more serious issues which need to be addressed and your response is that it's been fine for a year and if the engine goes bang then who cares. If that is actually your attitude then why the question in the first place? It would appear that I as a total outside care more about the condition of your engine than you do?
    Your definition of fine is not in line with more knowledgeable members of the community's definition of fine. If you can't accept our help in whichever form it comes then that is your loss, no need to leave the forum over it though. Maybe if you stuck around you'd learn more about your engine and get it running better? (because it won't be with an atmospheric valve routed like that)
    Your choice mate.
    Then never do them.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,603
    Baileys atmos valve getting the leak test treatment
    Used Bailey atmos dv bubble test | Facebook
    <tuffty/>
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Bugger the popcorn was ready and i was expecting a Jardo Attack and............................................... ....nothing but nice ness
    Lou have you tied Jardo up and pretending to be him????
    A3-Lee likes this.
    Aug 2011
    Plymouth
    759
    Add Lavis89 on Facebook
    mine was in a similar position to that when i bought the car (but with the 4mm line going into a different place i believe) binned off the baileys and bought a forge FMDV008 and put it back to the standard position for these engines. noticed and instant difference, ran alot smoother
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Vent pod boost gauge, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave (RIP) adjustable tie bars, FMIC
    Soon to be done: SAI delete, 3" Catback, Stage 2 remap
    RIP S3dave
    May 2004
    nr Glos
    7,190
    nice attitude................
    now have a good look at how your valve is likely to be performing... Used Bailey atmos dv bubble test | Facebook
    atmos = an air leak and poor fuel trims, which is why recirc dv's are fitted as std and advised
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  28. #27
    RIP S3dave
    May 2004
    nr Glos
    7,190
    oh and btw - your attitude stinks
    www.badger5.biz
    bill@badger5.co.uk
  29. #28
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    448
    dump valve
    Well congratulations all you have done is made your self look like a cock why ask a question if you don't care about the answer you get? Is it because you didn't hear what you wanted to? You will get no we're on this forum with your attitude and if you give people chance and listen this forum is actually very useful!
  30. #29
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,082
    Don't let the door hit you on the way out.
    X
    Lavis89 and A3-Lee like this.
    Then never do them.
  31. #30
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    448
    dump valve
    Quote Originally Posted by 16Klappe View Post
    X
    You actually remind me of me lol
  32. #31
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    if your not happy with the information you were given, please feel free to look elsewhere. Being rude to other members will get you nowhere. Where else can you get the information, helpfulness , knowledge and experience you have received on this forum free of charge? So may i suggest you should think before being disrespectful to others.
  33. #32
    Sep 2010
    Devon
    756
    Being told off by our beloved mother superior is definately the end of the road....
    Badger 5 tuned 340 bhp / 350 lbft sleeper
  34. #33
    27,122
    & someone actually clicked "LIKE THIS POST"???
  35. #34
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,603
    I suspect it was more in ref to the latter part of the post where he bid us farewell
    <tuffty/>
  36. #35
    27,122
    Lets hope so
  37. #36
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    My like certainly was. What a nobhead.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  1. Best Diverter Valve/Dump Valve
    By ScottyKemp in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2003, 13:11
  2. Dump Valve/recirc valve?
    By Jinx in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2003, 23:53
  3. Blow off valve or Dump valve ?
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2003, 19:18
  4. Dump valves
    By waynehiscock in forum General Technical / How To
    Last Post: 28th March 2003, 18:15
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
