Badger5Chris Nott
Thread: Wiring?
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    Wiring?
    Hello,
    i have got my car back from the dreaded oil pressure it seems ok so im gonna continue with my project of the interior, my question is wheres the best place to send wires through from engine bay, i have to send a power cable plus a cable for a boost guage and one for oil pressure ironicly, ive heard of a spare gromet but cant find it pictures would help me endlessly.
    Tim
    Nov 2012
    Kent
    459
    Well i finally found it broken a few plasitc bits :/ anyway i have to wires now, just wondering about fuses?
    i will be running 3 gauges and 2 neons tubes off the switched live thats by the relays under the sterring wheel do i need to add an inline fuse for these and if so what rating? and i have power straight from battery to the 3 gauges same question there too?
    Tim
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Wiring?
    Did you run the wires through the grommet behind the glove box?
    Regarding the wiring for the gauges, I think you should have two power wires for each gauge, a constant 12v and an ignition live, or just an ignition live, illumination and an earth.
    I can't remember what I had on mine, I know I had ign live, illumination and earth but I didn't run any extra fuses and they've been on there for a few years without any issues.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Nov 2012
    Kent
    459
    yeah i did was pretty easy thankfully once finding it, also the actual wiring im ok with its just the fuses ima bit iffy about there will be a constant live to the battery and a switched live to the one by the realys, not sure if i need to fuse either of them but as u say u havnt and its been fine i might just not worry, tbh it should be alright... famous last words :P
  1. AIRBAG WIRE's S3 SEATS
    By lakhan in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2004, 13:48
  2. window wire
    By cradford1 in forum Classic Audi Forum
    Last Post: 11th February 2004, 20:24
  3. how to wire up the foglights to come on alone
    By indica in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th December 2003, 16:45
  4. NewB, need help: Wire color: delta radio
    By VuDuStetson in forum In-Car Entertainment
    Last Post: 24th November 2003, 16:07
  5. Wiring loom from S3 (BOSE SETUP)
    By danbrier in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2003, 23:53
