i recently changed the temp sender as i had a fault code come up, not sure what one at this moment in time, when the new one went in, code was still there so i put the one one in, when the ignition is on i get 3 beeps and a thermometer flashing on the dash, now this happens even if the engine is off, im guessing this is the thermostat and can a faulty thermostat cause bad fueling
looking to do rear diff oil soon, what grade and what volume does it hold?
and are the rear brakes on my a3 quattro, pre facelift the same size as s3 rears?
thanks
thanks
