EM TuningChris Nott
    Jan 2013
    17
    Stuck mirror screw
    Hi , In the process of repairing my mirror but one of the underside screws ( closest to car) is stuck in ( the mirror isnt attatched properly , the top is away from the bottom the /tabs are apart) and trying to undo only strips the head , have sprayed lube inside to no luck .... Any ideas?
    Dec 2012
    bridgend wales
    51
    hi if its the plastic cover under the mirror i had the same problem the other day. drill around the screw into the plastic so you have a complete circle of holes around the screw you can then break the cover the use mole gripes or pliers to remove the screw but do this fairly gently so it dosnt snap. a new plastic cover from audi is 7.85
  1. Just bought some Alu mirrors for 250!!
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2003, 21:51
  2. Funny passenger side wing mirror.
    By Gambba in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2003, 08:44
  3. Alu Mirrors
    Last Post: 22nd February 2003, 17:42
  4. Aluminium Mirrors - Where to buy????
    By tommyt in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2003, 10:46
  5. heated mirrors not working.
    By moschino in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2003, 17:14
