I havent run any logs.
Ok to be a bit clearer, after various pipes popping leaks and getting fixed, I EGR deleted it and promised myself an upgrade side mount and hard pipes.
The EGR delete was welded up after it was blowing a little oil out of it.
A hard pipe and uprated alloy side mount was fitted. I drove home with vibrations that got worse, kwikfit ramps the day after and I could see the bottom pipe hanging on the driveshaft.
Garage who fitted it all had another go on saturday afternoon, they made a solid pipe up on another car from the turbo with a small silicon hose connecting to intercooler.
Top pipe section seems ok.
under boost its obvious theres a leak from the noise. but I couldnt see it jacking the car up and revving it.
Sure Ive let them know theres another problem, but how many more times will it need fixing, im doing 80 mile round trips to the garage and getting no work done. I suppose I could ask the original pipework and intercooler is refitted and im refunded, but I havent heard other people having this problem with this garage!
