Chris NottBadger5
Results 1 to 8 of 8
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    dipstick rubber ?
    Hi all,
    Just come to replace my dipstick housing. The old one was snapped and I think who ever had it before put like rubber heat shrink stuff around it? Or is that meant to be there, or should the housing go straight onto the metal? The new housing I got wont go over the rubber but if I pull it off should go over the metal.
    Is this correct?
    .Ben.'s Avatar
    Nov 2012
    Guildford, Surrey
    114
    If it's a 1.8T, it should just be an orange plastic tube that clips over a metal tube coming out of the sump. It's about 9" long.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Pull the rubber crap off and shove your new one on..
    Jul 2012
    24
    My dipstick housing is broke, where about did you buy your replacement 1 from?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Audi only part but cheap..
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    878
    Add Vex182 on Facebook
    Agreed, I think it's about £3.20 + vat.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    191
    yep, the part was less than £5.00 inc vat (from Audi). They had to order it in but only took a day to arrive. Who ever has tried to fix it has done a bodge job and the rubber thing was such a hastle to remove.. So I need to now remove the old oil filter. It's well untruely stuck on tight. Someone said to bash a screw driver through it and use that as a lever. Good idea?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yeah no harm in doing that, it needs a new one anyway..
  1. New S3 owner - rubber mats?
    By S3ABZ in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2004, 11:27
  2. New Rubber
    By Masterm8fo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2004, 11:44
  3. Cleaning rubber side strps
    By jesters3 in forum Detailing
    Last Post: 16th June 2004, 23:32
  4. 2.8Q suspension/rubber/rim upgrades....
    By cstm28Q in forum Handling
    Last Post: 8th August 2003, 07:37
  5. TT Replacement rubber
    By marsha in forum Other Brands & Models
    Last Post: 2nd August 2003, 18:23
