EM TuningBadger5
Results 1 to 8 of 8
    Feb 2013
    Solihull
    Looking to buy an s3 8l
    Hi guys, im going to look at a couple of s3's tomorrow and im just after some advice as what to look out for and what the common problems are.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    May 2010
    139
    I've heard Clio 182's are way better and have a better spec standard, probably have a look at afew of them also!
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    491
    Quote Originally Posted by demons uk View Post
    You are a disgrace to the forum
    AMD stage 2 map, BBS LM 19s, 20mm Momo Spacers, Black Diamond Discs, Ferrodo ds2500 pads, Milltek Exhaust, Pipewerx downpipe and Decat, Custom FMIC, 4 bar Fuel Pressure Regulator, Forge 007p, Forge short shift, Forge DV relocation ,Forge TIP, S2000 Filter, Sachs Race Clutch, Sachs Light weight Single mass flywheel, ForgeOil catch tank, De baffled Charge pipe & Polished, Polished Inlet Manifold, N249 Delete, PCV Delete, Red Engine Mounts, Forge Boost hoses, Angel Eye Headlights, LCR Splitter,
    Jan 2011
    Glasgow
    233
    Quote Originally Posted by Danny Cawsey View Post
    Main things to look for I'd say:
    Corrosion, usual spots are bottom of doors, roof rails and front arches quite poor for a car that's meant to be galvanised that's another debate...
    Haldex (Quattro)wiring issues or noises, skipping when on full lock. Due to poor servicing mainly.
    Rear wiper motor or washer jet being intermittent or not working.
    Wear on leather bolsters
    Stock head units can have a fault when volume is adjusted even slightly can make the speaker volume on max all the time.
    Wear on switch gear for example headlight controls and climate control the paint just comes off and looks terrible some cars are worse than others some are perfect.
    Chrome trim around gear knob can chip and flake off
    Broken glovebox hinges
    Previous owners covering warning symbols on instrument clusters to hide ESP errors for example. (Happened to me)
    Brake servos are known to be a weak point.
    broken springs suspension.
    Alarm siren fails and the warning for this is beeping on startup
    instrument cluster the LCD screen in the middle starts to gets line and becomes hard to read.
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,061
    Visit 16Klappe's Instagram Channel
    I heard your S3 was really slow.
    I quite often say I'm going to do things.
    Then never do them.
    Feb 2013
    Solihull
    Cheers for thr replys. What are these cars like at handling milage because the 3 that im going to view, 1 has got 85k, 1 has got 98k and the other has 108k. All are the pre face lift models so I presume are the 'apy' engine? Also what are the cluthes like because I will be looking at getting the car remaped.
    May 2010
    139
    Quote Originally Posted by 16Klappe View Post
    Oh it is, still its an S3
    They handle mileage well but look for a good service history with regular oil changes, factor in the cost of dropping the sump and changing the oil pick up. The clutch wont last long with those mileages and remap...unless they've been done already.
  1. My brother is looking at buying a 2001 A6
    By imported_BShow in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th September 2004, 13:35
  2. Anyone looking at buying a new A3 should read this
    By imported_ilclifford in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2004, 20:14
  3. MOVED: Anyone looking at buying a new A3 should read this
    By imported_ilclifford in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2004, 22:04
  4. looking to buy an a4
    By imported_confused1834 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th August 2004, 20:45
  5. New and looking to buy a..........
    By Paulgs in forum The Welcome Section
    Last Post: 11th November 2003, 00:48
