AH FabricationsEM Tuning
Results 1 to 11 of 11
    Alais DJA's Avatar
    Feb 2012
    Southampton
    556
    Losing Brake Fluid - Possible Scenarios
    Morning all.
    Starting to lose Brake fluid over a few days, and clutch pedal keeps sticking every now and then on depression. No noticible leaks, however the rear pads have gone to the metal ( and are getting replaced Sat )
    Any ideas.
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,026
    Clutch master cylinder, slave cylinder or the pipe going into the slave cylinder are likely culprits...
    <tuffty/>
    Alais DJA's Avatar
    Feb 2012
    Southampton
    556
    I suspected as much - each part wont cost me more than £20.
    On another side note though - do you need to remove the steering wheel to replace the washer stalk>? And stickies about?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,026
    Quote Originally Posted by Alais DJA View Post
    ....On another side note though - do you need to remove the steering wheel to replace the washer stalk>? And stickies about?
    Yes you will... don't know of any on here that I remember but I would disconnect the battery and leave it 20mins before attempting to remove the airbag/steering wheel... there should be steering wheel removal guides on places like VWVortex, UKmkIV's etc...
    Or look for the guide to fit cruise control as the PDF from VW Teeside has this in it...
    <tuffty/>
    Alais DJA's Avatar
    Feb 2012
    Southampton
    556
    diagnosed the problem to a small silver unit with a pipe in each end sits above the near side wishbone ( and where the fluid is collecting )behind the battery suspended by two metal pipes each end.
    can anyone confirm what the name of this unit is...
    so far i've been told pressure release valve / non return valve / dampner valve
    any help as always greatly appreciated
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,026
    Got any pics?
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,026
    ...actually I have an idea of the bit you mean... fitted to the bulkhead?
    <tuffty/>
    Alais DJA's Avatar
    Feb 2012
    Southampton
    556
    yeah, small silver unit size of a golfball.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,026
    Dealer only part as far as I know... dunno the PN or what its called off hand... have heard of these 'leaking' before... have you tried tweaking the unions at all and give them a clean with brake cleaner after to see if its still leaking?
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    It is a reducer damper valve, see Superkarl his went..
    Alais DJA's Avatar
    Feb 2012
    Southampton
    556
    The feelers are out at the moment at my garages i manage to find me one now, im going to clean up and tighten it up tonight see if it leaks any more under load. will keep you updates
  1. losing brake fluid
    By symeon in forum Classic Audi Forum
    Last Post: 26th March 2006, 09:02
  2. Renewing brake fluid and coolant
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2005, 17:35
  3. brake fluid
    By 17AUG2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2005, 09:25
  4. Brake Fluid Change
    By Masterm8fo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2004, 23:41
  5. Brake Fluid
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2003, 23:39
