Sky InsuranceChris Nott
Thread: thermostat help
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    thermostat help
    Hello,
    I know this has probably been covered already, but I'm in need of help! I have just come to change my thermostat as it's knackered. So I followed a guide and got to the point where I remove the hose prior to thermostat. Engine coolant is now all over my garage floor. I expected some but not the lot. Is there any cut off to minimilise coolant loss? If not, where/how do I drain the coolant sufficiently? Is there somewhere near rad?
    Pleassseee helpp!
    Thank you.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    There is a plug by the RAD, but it sounds like the damage has been done, there wont be much more coming out....
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    lol ok. I'll see how it goes.. I only got my t/belt and water pump done yesterday with fresh g12... which is now all over my garage floor :P.
    Well I'll try and bucket the rest out of my rad and put it back in..
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Hmmm it would have been a good shout to do the thermostat at the same time then...
    May 2010
    139
    I got a lot more out once I'd removed the housing, so be warned and cover the dip stick tube ;-)
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Quote Originally Posted by demons uk View Post
    The housing came straight out with the clip that holds it on to the block.. I think it's already been snapped and shoved back in, so i'll buy a new one.
    I did ask the bloke to change it out when doing the w/pump and t/belt, but he just didn't bother.
    So I did it lastnight, it wasn't as hard as I thought to undo the bottom bolt, seeing as I had the tools. I think the hardest part was trying to put the butter fly clip back on to the hoses. I ended up using a jubilee clip..
    Also, the t/stat that I took out was completely snapped, i.e. the only part that was in there was the metal ring. No spring or cylinder.. I have no idea how/where that stuff has disappeared. Anyway I replaced it and now she sits at 90 perfectly ;-).
    Thanks for your help, and I'm sure i'll be back soon with more questions.
    - Spat
  1. A little thermostat help? 01' A3, AVU engine.
    By dcskinx in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2013, 20:29
  2. thermostat help, hertfordshire
    By jamieA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2012, 15:49
  3. 01 Audi S4 thermostat help
    By Devious25 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 1st January 2012, 18:08
  4. Thermostat help
    By macpdm in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2011, 20:57
  5. Thermostat HELP needed Please
    By 0morg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2011, 09:20
