Volks AutosMonster Motorsport
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By rustynlc
  • 1 Post By lsukltd
Thread: Damp/Leak into Drivers footwell, Help Needed!!!!
    Diesel Quattro's Avatar
    Sep 2009
    Cheshire, UK
    119
    Help Needed please,
    my footwell is adamo and its not from wet feet going in and out.
    i am not sure where to start??
    any common problems people know of??
    would something as simple as the vin number plastic breaking, would the water go down there i.e. have a path to get to the footwell??
    thanking you
    aaron
    2001 a3 tdi Quattro
    A3 Tdi Quattro 3Dr 51 Plate
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    if the black scuttle panel that has the window in it for the vin number doesnt clip into the bottom of the windscreen properly on the passenger side then the water can go in there and down through the pollen filter and into the passenger footwell
    Ali
    Sep 2009
    Cheshire, UK
    119
    Hmm, thankyou. well this is the Drivers footwell and i have no idea where to start looking??
    do the heater matrixs leak?? anyone got any experinence of their driver footwell??
    any help would be appreciated
    aaron
    Jun 2012
    Redhill Surrey
    629
    Add Grale1 on Facebook
    Hi did you manage to find where yours was leaking from? I have a wet drivers footwell also
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    373
    Hmm me too!? Has it got something to do with drivers side lower corner of windscreen not fitting properly allowing rain water to leak in behind the dash and into the foot well?
    Jul 2011
    wiltshire
    121
    I have this problem, I'm thinking its getting in via a grommet/bung somewhere along the scuttle panel, ill be looking for the source of the leak this weekend! Been dry in the drivers footwell all week, started hammering down today and the wet patch appears! Definitely rain water!
    Pubemammal likes this.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    373
    Quote Originally Posted by rustynlc View Post
    Let me know how you get on
    S321BAM's Avatar
    I lost the rod lottery
    May 2010
    Plymouth
    101
    I had this problem a while ago. Ended up being a missing gromet from previous owners stereo install on the scuttle panel by the passenger side inner arch
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    i had a wet driver side footwell, mine turned out to be the grommet where the bonnet release cable runs though had split letting water run in.
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Mar 2013
    Devon
    394
    Quote Originally Posted by jay1601 View Post
    Bonnet release cable grommet is common, also the black plastic cover in the plenum chamber under scuttle often leaks, especially if aftermarket cruise control has been fitted, they rarely seem to seal properly after being disturbed.
    Sunroof drains and drains in the bottom of the door also worth checking.
    Jan 2014
    Oh Gosh I've experienced same issue, I am not mechanical minded at all and would need some recommendations to reliable garage. My Drivers Foot well is soaking when raining. I am in SW London someone who knows what they are doing.
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    729
    Quote Originally Posted by JimS3 View Post
    The drains at the bottom of the doors? Can you elaborate? If they are blocked, how do you unblock them (successfully)? Or is it just a case of keep on checking and unblocking? I'm assuming my doors are the blame as they are rusty and I have a damp drivers' footwell. The OSR door is the same but no damp in the back.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
  1. leak into passenger footwell
    By tmint in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2012, 22:25
  2. Aftermarket headunit into 1998 A3 help needed please.
    By Jimmybeattie in forum In-Car Entertainment
    Last Post: 3rd September 2010, 14:01
  3. Replacing my driver seat' HELP NEEDED, CONNECTIONS
    By paul26982 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2009, 21:34
  4. Water leak into rear footwell
    By AndyMac in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th November 2005, 17:45
  5. Leaking Drivers Footwell HELP?
    By DaveS3Turbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2005, 19:55
