JMB RetrofitsEM Tuning
Results 1 to 8 of 8
    dan-quattro's Avatar
    Sep 2008
    Staffs
    149
    EML displaying & temp problem
    Hi all,
    My 2001 AMK S3 is playing silly buggers with me and I have a long list of jobs to get sorted.
    Top of the list is an engine management light that's displaying - 2 previous diagnostics have shown 1 being an intermittant missfire & 1 as running lean.
    Now, the other problem is the fact that my cooler temp is showing 80c-85c when driving on open roads to work 40/50/60mph but then when slower through towns and idling it rises to 90c. Thought it was the cold weather but the previous 4 years of ownershsip cold weather has never affected it and it's always hit 90c everyday constantly. Is is possible that the 2 are linked somehow?
    I am booked in this friday with Midlands VW for a more in depth diagnosis with the guys there to pin point exactly what's going on, but any ideas what to possibly expect?
    Thermostat, MAF sensor, vacum hose?
    Cheers for any help, need to get the car sorted ready for an M.O.T end of Feb.
    Audi S3 2001 AMK, Milltek Cat-Back Exhaust, 18" TT Wheels, Black Leather Recaro, x1 Very Happy Driver
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Change the coolant temp sensor, green, 4 pin sensor on the gearbox end of the head, costs about £20, this sensor controls more than just the gauge, and could well be your issue with running lean, id also say change your thermostat at the same time, that will cure your temp gauge movement
    Sep 2008
    Staffs
    149
    Cheers Phil, hopefully fingers crossed a relatively cheap fix to my problem then.
    Seems alot of temp/stat problems of late!
    Sep 2012
    Devon
    843
    My gauge was doing silly things on the odd time id look down and see the gauge going from 90 down to like 70 then go back up, so on monday i replaced my sensor (we keep them in stock) and i must say it seems to run better, so it was more than just the gauge being messed around, for the amount it cost i dont know why i didnt change mine when i was putting all the new bits on
    Sep 2008
    Staffs
    149
    Oh well car will be handed over to a VAG specialist tomorrow to have a leaking power steering coolant pipe replaced and the EML light and temp problem diagnosed.
    Hopefully know the problem tomorrow and can act on it.
    Mar 2011
    Warwickshire.
    246
    Quote Originally Posted by dan-quattro View Post
    My temp gauge has gone weird too! When i put my heaters on it drops from 90 to about 60, turn heaters off and it goes back to 90 but takes about 10 mins to get back upto 90.
    Thermostat or temp sender?
    Cheers.
    A3 quattro Sport
    Forge 007p Pipercross panel filter R-Tech stage one map (213BHP)
    Oil catch can mod, SIA delete, EGR valve delete. Forge EGR delete plate.
    kite's Avatar
    Oct 2007
    East Berks
    675
    Re: EML displaying & temp problem
    Quote Originally Posted by markthenewt View Post
    Cheers.
    Stat.....
    A4 (b6) 2.5 TDi QS Saloon.
    Sep 2008
    Staffs
    149
    Problem solved!
    Split vacuum pipe under the inlet manifold was causing an air leak which was why she was running lean.
    Thermostat needs replacing too.
    Had the split repaired today, stat is getting done in the week.
    Driving home felt like a new car, over the last few weeks I was convincing myself it was driving the same as ever, how wrong was I!
  1. Still have Water Temp Problem(After Changing Stat)
    By THE MONSTER in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd February 2010, 20:53
  2. Coolant and temp problem
    By low610 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2010, 20:12
  3. tt temp problem!
    By H-M3 in forum TT/TT-S/TT-RS Forum
    Last Post: 18th February 2008, 10:21
  4. rns-d system amp upgrade problems..... strange distortion!
    By shufti in forum In-Car Entertainment
    Last Post: 17th November 2007, 17:06
  5. Water Temp Problem
    By m_o_w_g_l_i in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th December 2005, 23:16
