Chris NottSky Insurance
Results 1 to 7 of 7
    Yohan87's Avatar
    May 2011
    405
    Strange vibration through all pedals
    Car = VW Bora 4motion with 1.8T AMK
    Morning,
    I've noticed that when accelerating and on the over run I can feel vibrations through all 3x pedals. It's a strange one to describe but when accelerating it's like the car feels rough or gritty, even though it pulls smoothly through the rev range and very well.
    Again on over run I can feel what I'd described as a constant but not severe vibration through all the pedals.
    The car does have an SMF and a poly dog bone mount but it has only started this vibration thing recently. I've checked the dog bone and it's torqued to the correct specifications.
    Also at Christmas I removed the air con unit as I plan on slowly turning it in to a track car and I replaced the belt. Would the removal of air con cause more vibrations since that pulley no longer requires turning?
    Sorry for the vague description but hopefully somebody understands what I'm on about.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Can you feel it static to rule out any suspension issues?
    Yohan87's Avatar
    May 2011
    405
    Nope, seems smooth on idle.
    Could it even be a wheel balancing issue?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Could be, try coasting and see if its the same?
    Danny-boy's Avatar
    Jan 2013
    477
    Could it possibly be "saw-toothed" tyres mate?
    Dan
    Yohan87's Avatar
    May 2011
    405
    Right I did some testing tonight and it seems to happen only when throttle is applied.
    Stationary and in neutral, if I rev it up slowly and feel the clutch/brake pedal with my left foot I can feel small vibrations coming through them. Worse when moving and car is under load.
    When moving at any speed and I dip the clutch and coast there is no vibrations. Seems to be related to throttle action.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Sounds like the flywheel, or a bent pulley?
  1. Vibration through clutch pedal
    By 666markyboy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th June 2012, 21:01
  2. How does your A4 drive - vibration through accelerator pedal?
    By PATCH in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th March 2009, 18:12
  3. serious vibrating through steering wheel and pedals?
    By jarvis**turbo** in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2008, 22:02
  4. Vibration through clutch pedal
    By grey99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2006, 22:42
  5. engine vibration through steering????
    By A3Lee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th October 2003, 01:10
