EM TuningSky Insurance
    Dec 2012
    strange indicator fault
    hi all, sorry if this has been done before but couldn't find anything with a search. so the last three times i have used the car after 5-10 mins the indicators stop working both using the stalk or switching on the hazards. example, set off for work this morn and all was well, about ten mins in to the drive once it was warmed up i noticed the indicators had stopped working, so once i got there i checked all other lights fog, brake, headlights you get the idea, all working. next i checked the fuses and again all well, so confused i got on with work and checked them again before the drive home and they were working again so set off, again half way home they packed up around the time it had warmed up.... i dont get it, is it something to with it being so cold then getting hot. it also done the same last night as i indicated to pull into my drive, i have no idea to be honest so any ideas or a link to a similar fault would be much appriciated. cheers jay
    if its not broke... tinker anyway
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,182
    9 out of 10 indicator issues are caused by the relay being on its last legs. It's behind the hazard button but is actually part of the button so you'll need to order a new one. Not an expensive part if that's the issue. Should be your first port of call I'd say.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Replace the hazard light switch... common problem discussed many a time on here... around 35 quid for a new switch
    The switch contains all the relays and controls for the hazards and the indicators...
    <tuffty/>
    Dec 2012
    cheers guys much appriciated
    Nov 2012
    Kent
    451
    Add Tim_Attard on Facebook
    Dont buy a new one yet, i had a problem with mine a few months back and same as above was the relay but its quite easily fixed if its that, take it apart (theres a vid on youtube) and ur be able to see the relay get a small flat head and scratch away at the contacts and bend it a bit closer this makes it have more of a good contact between the plates which fixed my issue will save u £35 just have a look on youtube for a how too vid, im not that mechanical but managed to do it no probs
  1. Strange sensor fault
    By 666markyboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2010, 15:23
  2. indicator fault???
    By stu86 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2009, 23:07
  3. Indicator fault
    By Anim in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2008, 13:30
  4. Indicator fault - diagnosed. Step by step guide to replacement.
    By bebecheekymonkey in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th September 2007, 22:24
  5. indicator fault
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2004, 19:06
