EM TuningAH Fabrications
Results 1 to 8 of 8
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    Xenon headlight level sensor
    Hi I replaced my rear tie bars for adjustable ones last year but never attached the Xenon headlight level sensor just wondering if it will effect my car when it comes to MOT time and should I need to have it fitted on to the new tie bar?
    epox's Avatar
    Oct 2012
    Glasgow
    561
    hi
    dont know if they check selfleveling in the mot just yet?.
    However my front sensor was nacked and lights were poo.
    Replaced the sensor, lights now level and are much better, i would reconnect thesensor anyway.
    mark
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,055
    Worth getting it done mate, it can be checked on your MOT and will fail if its not working, also if your lights are not levelled, you could end up dazzling others and there is nothing more annoying that xenons dazzling you.
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    My headlights are pointing up a bit and I have had some oncoming traffic flashing their lights at me thinking I was driving with full beams on does anyone know what the actual part is called?
    epox's Avatar
    Oct 2012
    Glasgow
    561
    • 1 - → Subframe
    • 2 - Bracket
    • 3 - Upper transverse link
    • 4 - Connecting link
    • 5 - Nut, self-locking, 5 Nm
      • Always replace after removing
    • 6 - Lower transverse link
    • 7 - Clip
    • 8 - Rivet/self-tapping screw, 9 Nm
    • 9 - Rear left vehicle level sender -G76
      • Do not detach connecting link from ball end
    Nilz's Avatar
    Apr 2006
    10,055
    I think it is actually headlight level sensor.
    Im sure you can manually adjust them as well, if you pop your bonnet, next to the hadlight, there is a white plastic screw, you need a star screwdriver and you can adjust it using this.
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    789
    From the diagram it looks like it is the&nbsp;&nbsp;Rear left vehicle level sender -G76 this was snapped snapped off at the connection on the original tie bars have a picture here if it helps<br>
    Could always try and adjust the lights from the white plastic screws that are on the lights
    epox's Avatar
    Oct 2012
    Glasgow
    561
    just get a new sensor/ old one from ebay, easy fix. not sure how much adjustment on the lights.(they will still dazzel depending on car load)
    cheers mark
  1. Xenon rear levelling sensor
    By ilim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2012, 23:13
  2. Xenon Level Sensor Rod Replacement?
    By coyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2010, 18:57
  3. Setting xenon headlight level with Vagcom (8L S3)
    By Andy_S3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th October 2009, 22:22
  4. Adjusting xenon headlight level on 8P3
    By yahyar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2009, 23:58
  5. S3 Xenon headlight levelling -
    By subby in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2009, 11:03
