Monster MotorsportEM Tuning
    imported_Nigma
    battery or something else?
    Car behaving very strangley over the last couple of days.
    Went to start the car on saturday and turned over very slowly, but did start in the end. The strange thing was that the doors locked as i did it and also the trip millage had been reset.
    Then went to start it yesturday, and it VERY slowly turned over and almost sounded like it was dying. Wouldn't start. In the end, jump starting with another car worked. The strange thing was that the car stereo went into "SAFE" mode, which must have meant the battery was disconnected.
    Drove it around a bit went shopping and returned to the car, and it started but did the wiered stuff above (doors locking).
    It just came out of service last monday, which is ever more annoying.
    Any help would be appriciated.
    Thanks Anand
    imported_monkeytrousers
    Re: battery or something else?
    Not sure but I thought you weren't supposed to jump start the 1.8T engines? Sure someone more knowledgable will clarify.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Battery is dead. Replace it and im sure the problems will be solved. Using jump leads attached to another car is perfeclt OK... Push starting is what your NOT supposed to do.
    Rich
    Timbo's Avatar
    Slowest car ever round the Top Gear track?!?
    Dec 2004
    Surrey
    275
    [ QUOTE ]
    [/ QUOTE ]
    I think I've heard this before in relation to cars with cats but I can't remember the reason why - can you elaborate Rich?
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    Can damage the cat with unburnt fuel being exhausted. Im not sure if its as much of a problem on injected cars, but not worth the risk anyway
    Rich
    imported_Nigma
    Well, had the battery replaced and now appears to be working fine (fingers crossed).
    Thanks Anand
