Chris NottBadger5
Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By s3welshy
  • 1 Post By IFFY_77
  • 1 Post By danderton
Thread: S3 Drivers Door doesn't shut
    Oct 2012
    Scotland
    17
    Guy's
    Having a quick through the forum but unable to find my exact problem. When i shut the door it catches the latch but doesn't fully close. Now if i do it really gently it is sometimes ok but not always. Is this the locking mechnism that needs to be replaced?
    It's going in for a MOT tomorrow and getting the timing belt changed as well, for bought the car a couple months ago and doesn't look like it was done yet. Car done 99k miles so think it's needing done at 115k but better safe than sorry.
    Was going to ask for the door to be looked at as well, but thought i would ask if it is something simple?
    Kenny
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Cam belt should be changed at about 70,000 miles and also change the water pump and tensioner damper as well while your at it,
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Oct 2012
    Scotland
    17
    Ok mate thanks will say that too when i drop the car off in the morning. Should maybe just give the guy a list, anything else you recon would be worth while?
    Feb 2012
    Rutland
    132
    Quote Originally Posted by plimpix View Post
    If it's not been done I would seriously suggest dropping the sump and cleaning / replacing the oil pick up pipe. A little search of the forum will show you that you don't want it clogging up and starving the engine of it's much needed lube!
    2001 AMK S3 in Goodwood Green
    Oct 2012
    Scotland
    17
    Figging 700quid worth of work to be done, i hate to think what it would have been if i had went to audi. And the garage i am using i have used before. Seems there is a list of things needing done.
    May 2012
    Barry, Vale of Glamorgan, United Kingdom
    55
    hi plimpix
    i have a 1999 s3 on 152000 miles. got very good history, i have had it since may 2012. i have spent about £600 since i bought it. all i can say is its worth every penny, mine seems sweer as a nut at the moment, theyre old motors nowadays.
    keep the faith theyre worth it.
    plimpix likes this.
    Oct 2012
    Scotland
    17
    I hope this is true of mine and it will run sweet as, any ideas on the door tho. In saying that it might come back fixed with the amount of wedge it's costing me for this mot.
    IFFY_77's Avatar
    Jun 2012
    London
    68
    I have the same issue with the door, im very sure its the door latch catch sum1 may correct me but its the mechanism on the actual door. Try greasing it if this don't work then u need to replace it as there is a spring inside that is worn usually drivers doors go first as it is most used. new part from audi was i think between £50-80 i last time i called. I greased it and now if i dont slam it its ok but i intend on changing it coz sumtimes it plays up but my money seems to be going on modding atm lol saving for a badger 5 Tip :-)
    plimpix likes this.
    Oct 2012
    Scotland
    17
    thanks mate, will see how it is when i get it back. Now looking at better alloy's was thinking of punting it on after it got MOT'd but i won't get that ££ back so will just keep it :D
    May 2012
    55
    any pics of your car mate?
    Oct 2012
    Scotland
    17
    Quote Originally Posted by s3welshy View Post
    Naw do not, i had bought it as a cheap run about till i move house. For had a 2010 WRX Sti Saloon before it but sold it cos i am moving house. But now i am spending 700 quid to get it though it's MOT i might just have to start making some changes. So will take some pics when i get it back. There are quite a few cosmetic things i wouldn't mind getting fixed then i think i will give it a full detail when i get it back, including paint correction.
    Feb 2013
    Carlisle, Cumbria UK
    7
    Hi, I'm having the same issue on my a3 with the door and was wondering if the greasing worked for you? I'm willing to try anything with it before I buy any parts that i might not need!
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Make sure the latch is fully back. It has two teeth so push it back more. Happened to me in the morning once.
    Nov 2012
    83
    I have had problems with both my doors not shutting properly. You would have to pull the door in or a good push for it shut. I found trying to close it with a little force - it just bounced off the latch. Trying the lock with a screwdriver it looked like it was latching properly but apparently a spring can go inside which causes issues.
    I replaced both locks - guide on the forum but was quite easy and it seemed to fix the issue. Locks i got off eBay for about £30 a lock
    Edit: reading comments above I actually found greasing it (my initial idea to fix) actually made it worse
    plimpix likes this.
    Oct 2012
    Scotland
    17
    So thanks for all the posts, now replaced the lock on the drivers door and now closes fine.. :D
    Now for the next thing drivers side replacement wing mirror glass..
  1. Drivers door frozen shut from the outside........
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2010, 21:14
  2. Drivers door shutting
    By StevoS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2009, 21:33
  3. driver door shutting problem
    By evilbow in forum General Technical / How To
    Last Post: 21st April 2009, 02:34
  4. Drivers Door Not shutting Properly
    By myrichdad in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2006, 19:17
  5. Door chime not shutting off
    By imported_TurboMan in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th August 2004, 18:16
