AH FabricationsBadger5
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By <tuffty/>
Thread: advise needed???
    Sep 2012
    West midlands
    368
    advise needed???
    i recently fitted a new actuator and done a pcv delete,decided too do a log on vcds today too see how things are running lets say
    results arent looking goodi did doo fuel trim reset and go straight out for a run engine was up too temp well and truely!!!first pull is 3rd intoo 4th gear and fuel trims block 032 were 0.0 and 0.3,it is pulling very hard now but ive spent too much too go blowing it up, so the high readings seem too be cylinder 1 and 2!! connector for knock sensor cylinders 1/2 wiring was pulled out i have reconnected the sensor and torqued up sensor too correct spec this was 3 months back when it had code when i scanned car on its return could it be sensor dud? or i have had inlet cam out recently too change vvt tensioner???ive got logs from before not hitting this sort of boot but highest cfs ive seen is 6?? abit worried too say the least!
    Sunday 27 January 2013 16:25:14:10074 VCDS Version: Release 10.6.4 Data version: 20110418
    8N0 906 018 BH 1.8L R4/5VT G01 0001
    Group A: '020 Group B: '002 Group C: '115
    Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization RPM Load Inj. On Time Mass Flow RPM Load Absolute Pres. Absolute Pres.
    TIME TIME TIME
    Marker STAMP °KW °KW °KW °KW STAMP /min % ms g/s STAMP /min % mbar mbar
    105.9 0 0 0 0 106.21 2200 30.1 3.74 18.03 106.52 2240 38.3 970 1000
    106.82 0 0 0 0 107.12 2320 38.3 3.74 17.42 107.42 2360 38.3 970 1010
    107.72 0 0 0 0 108.03 2400 42.1 4.42 22.67 108.33 2480 88 2260 1070
    108.63 0 0 0 0 108.93 2720 121.8 11.56 71.86 109.23 2840 144.4 2470 1690
    109.53 5.3 0 0 0 109.83 3200 191.7 19.04 145.64 110.14 3480 191.7 2370 2510
    110.44 5.3 0 0 0 110.74 3960 191.7 22.78 171.67 111.04 4200 191.7 2380 2510
    111.35 4.5 0 0 0 111.65 4640 191.7 21.42 195.86 111.95 4840 191.7 2390 2440
    112.25 4.5 3 0 6 112.55 5280 191.7 21.08 213.78 112.85 5480 191.7 2410 2320
    113.15 4.5 3 3 6 113.46 5840 191.7 20.06 222.36 113.76 6040 191.7 2310 2250
    114.07 7.5 3 3 6 114.36 6360 186.5 18.36 224.86 114.67 6320 45.9 970 2540
    114.97 0 0 0 0 115.27 5280 12.8 1.7 14.39 115.57 4800 17.3 970 1090
    115.87 0 0 0 0 116.17 4760 115 10.54 129.36 116.47 4840 190.2 2360 2070
    116.77 3 1.5 1.5 3.8 117.08 5000 191.7 20.4 205.61 117.38 5080 191.7 2360 2430
    117.68 3 3.8 3.8 6 117.98 5280 191.7 21.08 212.61 118.28 5360 191.7 2360 2390
    118.59 6 6.8 3.8 6 118.89 5520 191.7 20.74 218.83 119.19 5600 191.7 2260 2330
    119.49 6 6.8 3 5.3 119.79 5760 191.7 20.4 223.81 120.09 5840 191.7 2210 2230
    120.4 5.3 6 3 5.3 120.7 5960 191.7 19.72 223.08 121 6000 191 2130 2270
    121.3 8.3 6 2.3 4.5 121.6 6120 170.7 18.02 219.56 121.91 6120 142.9 970 2510
    122.21 0 0 0 0 122.51 5160 12 1.36 11 122.81 4760 12.8 970 1130
    123.11 6 8.3 0 2.3 123.41 4680 140.6 13.26 155.56 123.71 4680 191.7 2280 2290
    124.02 8.3 9 0 3 124.32 4760 191.7 20.74 191.17 124.62 4800 191.7 2270 2540
    124.92 11.3 11.3 3.8 3 125.22 4880 191.7 20.74 191.67 125.53 4880 191.7 1540 2540
    125.83 0 0 0 0 126.13 4840 12 1.36 0 126.43 4800 12 970 1150
    126.74 0 0 0 0 127.03 4560 12 0 9.69 127.34 4080 12.8 970 1030
    127.64 0 0 0 0 127.94 3720 11.3 0 7.86 128.24 3840 11.3 970 1000
    128.54 0 0 0 0 128.84 3800 11.3 0 8.39 129.15 3760 11.3 970 1000
    129.45 0 0 0 0 129.75 3680 12 0 8.61 130.05 3640 11.3 970 1000
    130.35 0 0 0 0 130.65 3560 11.3 0 7.86 130.96 3520 11.3 970 1000
    131.26 0 0 0 0 131.56 3480 12 0 8.19 131.85 3480 12 970 990
    132.15 0 0 0 0 132.46 3400 12.8 1.7 8.39 132.77 3400 17.3 970 990
    133.07 0 0 0 0 133.37 3360 17.3 2.04 11.61 133.67 3320 16.5 970 990
    133.97 0 0 0 0 134.28 3280 12.8 1.7 7.81 134.58 3280 12.8 970 990
    134.88 0 0 0 0 135.18 3200 12.8 1.36 7.89 135.48 3200 12.8 970 990
    135.78 0 0 0 0 136.09 3160 12.8 1.36 8.17 136.39 3120 12.8 970 980
    136.69 0 0 0 0 136.98 3080 12 0 7.53 137.29 3040 12 970 990
    137.58 0 0 0 0 137.9 3000 12 0 7.31 138.2 3000 12 970 990
    138.5 0 0 0 0 138.79 2920 12 0 7.08 139.1 2920 11.3 970 990
    139.39 0 0 0 0 139.71 2880 12 0 6.81 140 2840 12 970 990
    140.31 0 0 0 0 140.6 2800 12.8 1.36 6.92 140.91 2760 12.8 970 990
    141.22 0 0 0 0 141.52 2720 12.8 1.7 6.75 141.82 2680 12.8 970 980
    142.12 0 0 0 0 142.42 2640 12.8 1.36 6.64 142.72 2600 12.8 970 980
    143.02 0 0 0 0 143.33 2560 12.8 1.36 6.42 143.63 2560 12.8 970 970
    143.93 0 0 0 0 144.23 2520 12.8 1.36 6.44 144.53 2480 12.8 970 970
    144.84 0 0 0 0 145.14 2440 12.8 1.36 6.14 145.43 2440 12.8 970 970
    145.74 0 0 0 0 146.03 2400 14.3 1.7 6.94 146.34 2400 15 970 970
    146.65 0 0 0 0 146.95 2360 15.8 1.7 7.14 147.25 2320 15.8 970 970
    147.55 0 0 0 0 147.85 2320 18 2.04 8.25 148.14 2320 20.3 970 970
    148.46 0 0 0 0 148.76 2280 20.3 2.04 9.08 149.06 2280 20.3 970 970
    149.36 0 0 0 0 149.66 2280 20.3 2.04 9.19 149.96 2240 19.5 970 980
    150.27 0 0 0 0 150.57 2240 20.3 2.04 8.83 150.86 2240 20.3 970 970
    151.17 0 0 0 0 151.46 2200 20.3 2.04 8.64 151.77 2200 20.3 970 980
    152.07 0 0 0 0 152.38 2200 20.3 2.04 8.78 152.68 2200 20.3 970 980
    152.97 0 0 0 0 153.27 2200 20.3 2.04 8.56 153.59 2160 20.3 970 970
    1 153.88 0 0 0 0 154.18 2160 20.3 2.04 8.58 154.49 2160 20.3 970 970
    154.79 0 0 0 0 155.09 2120 21.1 2.38 8.67 155.4 2120 20.3 970 970
    155.69 0 0 0 0 156 2080 20.3 2.04 8.22 156.3 2080 20.3 970 970
    156.6 0 0 0 0 156.9 2080 20.3 2.04 8.08 157.21 2040 19.5 970 970
    157.51 0 0 0 0 157.81 2040 20.3 2.04 7.83 158.11 2040 20.3 970 970
    158.41 0 0 0 0 158.71 2000 19.5 2.04 7.67 159.01 2000 19.5 970 970
    159.32 0 0 0 0 159.62 1960 18.8 2.04 7.28 159.92 1960 19.5 970 970
    160.21 0 0 0 0 160.52 1920 19.5 2.04 7.56 160.83 1920 19.5 970 970
    161.12 0 0 0 0 161.43 1920 20.3 2.38 7.72 161.72 1920 20.3 970 970
    162.03 0 0 0 0 162.33 1880 24.8 2.72 9.25 162.64 1880 25.6 970 970
    162.94 0 0 0 0 163.24 1840 25.6 2.72 9.36 163.54 1840 25.6 970 970
    163.84 0 0 0 0 164.14 1840 25.6 2.72 9.28 164.45 1840 26.3 970 970
    164.74 0 0 0 0 165.04 1840 26.3 2.72 9.28 165.35 1800 26.3 970 970
    165.64 0 0 0 0 165.96 1800 27.1 2.72 9.56 166.26 1800 27.1 970 970
    166.55 0 0 0 0 166.85 1800 27.1 2.72 9.72 167.15 1760 27.1 970 980
    167.47 0 0 0 0 167.77 1760 27.8 2.72 9.5 168.06 1760 27.8 970 980
    168.36 0 0 0 0 168.66 1760 27.8 3.06 9.58 168.97 1760 31.6 970 980
    169.27 0 0 0 0 169.57 1760 51.9 5.44 21.14 169.88 1760 69.2 1030 1020
    170.18 9 9 1.5 0.8 170.48 1760 78.9 7.48 29.42 170.78 1760 82 1170 1160
    171.09 9 9 1.5 0.8 171.38 1800 83.5 7.82 29.92 171.69 1800 82.7 1160 1240
    171.99 9 9 1.5 0 172.29 1840 83.5 7.82 29.83 172.58 1840 80.5 1100 1260
    172.9 8.3 9 0.8 0 173.2 1840 68.4 6.46 21.33 173.5 1880 60.9 970 1150
    173.8 8.3 8.3 0 0 174.1 1880 57.9 5.78 19.19 174.4 1880 57.1 970 1080
    174.71 7.5 6 0 0 175.01 1880 54.9 5.44 19.33 175.31 1880 51.1 970 1050
    175.61 5.3 4.5 0 0 175.91 1880 42.9 4.42 14.11 176.2 1840 41.4 970 1020
    176.51 0 0 0 0 176.82 1840 40.6 4.08 14.39 177.12 1840 40.6 970 1010
    177.41 0 0 0 0 177.72 1840 36.8 3.74 11.47 178.02 1840 33.8 970 1000
    178.33 0 0 0 0 178.62 1800 32.3 3.4 11 178.93 1800 32.3 970 990
    179.23 0 0 0 0 179.53 1800 32.3 3.4 11.28 179.84 1760 33.1 970 990
    180.14 0 0 0 0 180.44 1760 33.1 3.4 11.47 180.74 1760 33.8 970 990
    181.03 0 0 0 0 181.33 1720 33.8 3.4 11.44 181.64 1720 33.8 970 990
    181.94 0 0 0 0 182.25 1720 34.6 3.4 11.42 182.54 1720 34.6 970 990
    182.84 0 0 0 0 183.15 1680 34.6 3.4 11.39 183.46 1680 34.6 970 990
    183.76 0 0 0 0 184.06 1680 34.6 3.4 11.31 184.35 1680 34.6 970 990
    184.66 0 0 0 0 184.96 1640 35.3 3.74 11.39 185.27 1640 35.3 970 990
    185.57 0 0 0 0 185.86 1640 35.3 3.74 11.44 186.17 1640 36.1 970 990
    186.49 0 0 0 0 186.76 1640 34.6 3.4 11 187.08 1640 35.3 970 990
    187.37 0 0 0 0 187.68 1600 35.3 3.4 11.03 187.98 1600 35.3 970 990
    188.27 0 0 0 0 188.57 1600 15 1.7 3.47 188.88 1520 15 970 980
    189.18 0 0 0 0 189.48 1120 19.5 1.7 4.42 189.78 1040 15.8 970 970
    190.08 0 0 0 0 190.38 960 15.8 1.7 2.83 190.69 880 15.8 970 970
    190.99 0 0 0 0 191.29 1320 12 1.7 3.33 191.59 1680 12 970 970
    191.89 0 0 0 0 192.21 2080 12.8 2.04 5.08 192.5 2040 12.8 970 960
    192.81 0 0 0 0 193.11 2000 41.4 4.08 16.17 193.41 2000 40.6 970 980
    193.71 0 0 0 0 194.02 2040 40.6 4.08 16.25 194.32 2000 39.8 970 1000
    194.62 0 0 0 0 194.91 2000 31.6 3.06 12 195.22 2000 29.3 970 1000
    195.52 0 0 0 0 195.82 1920 14.3 1.7 4.19 196.13 1920 14.3 970 980
    196.42 0 0 0 0 196.72 1840 12.8 0 4.14 197.02 1800 12 970 980
    2 197.33 0 0 0 0 197.63 1720 12 0 4.22 197.93 1680 12 970 970
    198.23 0 0 0 0 198.53 1600 12 0 3.78 198.83 1560 12 970 970
    199.13 0 0 0 0 199.45 1520 12 0 3.53 199.74 1480 12 970 970
    200.04 0 0 0 0 200.34 1440 12.8 1.7 3.58 200.65 1400 12.8 970 970
    200.96 0 0 0 0 201.25 1360 12.8 1.36 3.58 201.56 1360 12.8 970 960
    201.85 0 0 0 0 202.16 1320 12.8 1.36 3.22 202.45 1280 12.8 970 960
    202.77 0 0 0 0 203.07 1240 15 1.7 4.89 203.36 1240 24.1 970 960
    203.67 2.3 1.5 0 0 203.96 1240 45.9 4.42 11.14 204.27 1240 44.4 970 970
    204.57 2.3 1.5 0 0 204.87 1240 49.6 4.76 12.25 205.18 1280 48.9 970 990
    205.48 0 0 0 0 205.77 1280 48.1 4.42 12 206.07 1280 48.1 970 990
    206.39 0 0 0 0 206.68 1320 56.4 5.44 15.56 206.99 1360 63.9 1000 1010
    207.29 0 0 0 0 207.59 1400 69.2 6.12 19.14 207.89 1440 69.2 1010 1070
    208.2 0 0 0 0 208.5 1480 69.2 6.12 20.78 208.79 1520 71.4 1070 1110
    209.1 0 0 0 0 209.39 1600 75.9 6.8 24.08 209.71 1640 75.9 1130 1150
    210.01 0 0 0 0 210.31 1760 77.4 7.14 27.08 210.61 1800 76.7 1120 1190
    210.91 0 0 0 0 211.21 1880 69.9 6.46 22.47 211.51 1920 58.6 970 1140
    211.82 5.3 0 0 0 212.12 1960 51.1 4.76 17.58 212.42 2000 43.6 970 1050
    212.72 0 0 0 0 213.02 2000 38.3 3.74 14.14 213.33 2040 38.3 970 1010
    213.63 0 0 0 0 213.93 2080 47.4 4.42 19.19 214.23 2080 51.9 970 1010
    214.53 3 0 0 0 214.83 2120 55.6 5.1 23.19 215.13 2160 56.4 970 1050
    215.43 2.3 0 0 0 215.74 2240 58.6 5.44 25.31 216.04 2240 58.6 970 1070
    216.34 0.8 0 0 0 216.65 2320 58.6 5.44 26.19 216.95 2360 58.6 970 1090
    217.25 0 0 0 0 217.55 2400 57.9 5.44 26.56 217.85 2440 58.6 1110 1090
    218.14 0 0 0 0 218.45 2560 114.3 10.54 61.64 218.75 2640 129.3 1650 1560
    219.06 0 0 0 0 219.36 2840 155.6 13.6 86.25 219.66 2920 127.1 1450 1620
    219.96 3 0 0 0 220.26 3080 78.9 6.8 19.86 220.57 3080 27.8 970 1230
    220.87 0 0 0 0 221.17 3120 13.5 1.7 9.28 221.47 3120 12.8 970 1030
    221.77 0 0 0 0 222.08 3120 12.8 0 7.19 222.37 3080 12.8 970 1000
    222.68 0 0 0 0 222.97 3080 12.8 0 7.56 223.28 3080 12.8 970 1000
    223.57 0 0 0 0 223.89 3040 12.8 0 7.58 224.19 3040 12.8 970 990
    224.48 0 0 0 0 224.79 3000 12.8 0 7.81 225.08 3000 12.8 970 990
    225.38 0 0 0 0 225.7 2960 12.8 0 7.69 226 2960 12.8 970 990
    226.3 0 0 0 0 226.6 2920 12.8 0 7.33 226.9 2920 12.8 970 990
    227.2 0 0 0 0 227.5 2880 12.8 0 7.11 227.8 2840 12.8 970 990
    228.1 0 0 0 0 228.41 2760 12.8 0 7.03 228.71 2720 12.8 970 990
    229.01 0 0 0 0 229.32 2640 12.8 0 6.47 229.61 2600 12.8 970 990
    229.92 0 0 0 0 230.21 2480 12 0 6 230.52 2400 12 970 990
    230.82 0 0 0 0 231.12 2280 12 0 5.61 231.42 2200 12.8 970 980
    231.72 0 0 0 0 232.03 1600 12.8 0 4.19 232.32 1240 13.5 970 980
    232.64 0 0 0 0 232.93 1040 17.3 2.04 3.5 233.23 1000 18 970 970
    233.54 0 0 0 0 233.84 1160 14.3 1.7 2.61 234.14 1440 12.8 970 970
    234.45 0 0 0 0 234.75 1880 13.5 1.7 4.92 235.05 1720 13.5 970 970
    235.34 0 0 0 0 235.64 1520 12.8 0 3.92 235.95 1440 12.8 970 970
    236.25 0 0 0 0 236.55 1360 12.8 0 3.33 236.86 1360 12.8 970 970
    237.16 1.5 0 0 0 237.46 1400 63.9 6.8 19.28 237.77 1480 67.7 1000 1000
    238.06 1.5 0 0 0 238.36 1640 72.9 6.8 24.5 238.67 1760 73.7 1080 1100
    238.97 1.5 0 0 0 239.27 1920 75.2 6.8 28.42 239.58 2040 72.9 1090 1180
    239.88 0 0 0 0 240.18 2240 82.7 7.82 38.17 240.48 2360 91.7 1370 1290
    240.78 0 0 0 0 241.08 2600 95.5 8.5 47.47 241.39 2720 85.7 1230 1340
    3 241.69 0 0 0 0 241.99 2960 87.2 8.16 49.56 242.29 3080 86.5 1200 1350
    242.59 0 0 0 0 242.89 3280 85.7 7.82 54.39 243.2 3400 85.7 1190 1350
    243.5 0 0 0 0 243.8 3600 85 7.82 60.89 244.1 3680 85.7 1190 1350
    244.4 0 0 0 0 244.7 3960 188.7 17.68 168.33 245.01 4200 191.7 2390 2400
    245.31 0 0 0 0 245.61 4680 191.7 21.42 199.36 245.91 4880 191.7 2400 2470
    246.21 0 3 0 3 246.52 5320 191.7 20.74 215.19 246.82 5520 191 1990 2310
    247.12 2.3 0 0 0 247.42 5080 12 1.36 0 247.72 4720 12.8 970 1180
    248.02 0 0 0 0 248.33 4080 12 0 7.83 248.62 4080 12 970 1030
    248.93 0 0 0 0 249.23 3920 12 0 9.11 249.52 3840 12 970 1010
    249.82 0 0 0 0 250.13 3640 12 0 8.69 250.44 3520 12 970 1000
    250.73 0 0 0 0 251.04 3360 12.8 0 8.44 251.34 3280 12.8 970 1000
    251.63 0 0 0 0 251.95 3160 12.8 0 8.08 252.25 3160 12.8 970 1000
    252.55 0 0 0 0 252.84 3080 12.8 0 7.58 253.15 3080 19.5 970 990
    253.45 0 0 0 0 253.76 3040 38.3 3.4 20.72 254.06 3040 14.3 970 1030
    254.36 0 0 0 0 254.76 3000 12.8 0 7.33 255.06 2960 12.8 970 1000
    255.37 0 0 0 0 255.66 2840 12.8 0 7.25 255.97 2760 12.8 970 990
    256.26 0 0 0 0 256.57 2640 12.8 0 6.69 256.87 2600 12.8 970 990
    257.18 0 0 0 0 257.47 2480 12.8 0 6.28 257.78 2440 12.8 970 990
    258.07 0 0 0 0 258.38 2360 12.8 0 6.14 258.67 2360 12.8 970 990
    258.98 0 0 0 0 259.29 2320 12.8 2.04 5.78 259.58 2360 36.1 970 970
    259.89 0 0.8 0.8 0.8 260.19 2360 59.4 5.78 29.08 260.49 2360 61.7 970 1060
    260.8 0 0.8 0.8 0.8 261.1 2440 57.9 5.44 27.06 261.4 2480 63.2 970 1100
    261.71 0 0.8 0.8 0.8 262 2520 63.9 5.78 31.31 262.3 2560 63.2 970 1160
    262.61 0 0.8 0.8 0.8 262.91 2640 63.9 6.12 32.69 263.21 2680 64.7 970 1180
    263.51 0 0 0.8 0 263.81 2760 25.6 2.38 9.22 264.12 2760 13.5 970 1070
    264.42 0 0 0 0 264.71 2720 12.8 0 6.61 265.02 2720 12.8 970 1010
    Audi s3 8l 2003 silver,brembo brakes,custom front mount intercooler,forged rods,acl race bearings,3inch tip,forge 007p green spring 1 shim,5mm hubcentric spacers,pipewerx 3inch down pipe/200cell race cat,2.75 miltek back non resonated,new piston rings,n249delete,pcv venting too atmosphere,neuspeed quick shifter,uprated clutch/pressure plate...large port agu head,inline fuel pump
    work left/relentless v3 manifold/wmi/blue haldex/antilag/launch controll/custom map!!!!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,584
    Sorry but that data is not really helping and I thought that with all the problems you are having you were going to book in at Bills to let him give it a once over?
    I seem to recall that you have been having fuelling issues and all sorts of things and that your map is also a potential issue?
    All these posts and you still haven't got a proper map on the car yet dude... I suspect that must of your issues will be resolved once thats done...
    Take a screen shot of the run data rather than posting all the irrelevant stuff around it then maybe we can see whats happening but tbh until you have got a map suited to all the hardware you have on you are gonna be chasing your tail
    <tuffty/>
    burns3 likes this.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,584
    ...and my advice is... take it to Bill and get it on the dyno... that way at least you can see whats actually going on in context...
    <tuffty/>
    Sep 2012
    West midlands
    368
    I will book in with bill tmorow but I'd rather find the problem myself if its not map related then when I have enough funds I will go too bill for a map and not just a log /dyno run! But plz shed some light on the high cfs plz tuffty 11.3 cfs is bad!!!!!!! Seem too be cylinder 1/2
    Sep 2012
    West midlands
    368
    The worst log
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,584
    Its still a crap log presentation but... you are pulling 11's at one point and it looks like actual boost is way higher than requested... chances are this is related... the logs/runs are still a little inconsistent to be overly meaningful...
    You can see where you pull 11's the load drops off... can't tell if thats you or the ecu doing it which makes it difficult to diagnose...
    For decent logs you need to be in third... start from 200rpm, foot to the floor to the redline (or as safe/legal it is to do so) ... on the finished log in excel, click on the row below the column headers and go into view > freeze panes and freeze it so you can scroll the logs to the start of the run... either use the snipping tool (win 7) or screen shot (not a photo of the actual screen) and post that..
    Makes it easier to see everything in context...
    Heres one I prepared earlier..
    I would also do a log with actual timing advance (block 003) along with 020 and 118
    <tuffty/>
    darren t likes this.
    Sep 2012
    West midlands
    368
    log in 3rd gear tuffty looks alot better i done another one after logging 002 031 118 aswell cant find screen shot in excel???
    Monday 28 January 2013 13:01:44:10074 VCDS Version: Release 10.6.4 Data version: 20110418
    Group A: '003 Group B: '020 Group C: '115
    RPM Mass Flow Load Ign. Timing Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization RPM Load Absolute Pres. Absolute Pres.
    TIME TIME TIME
    Marker STAMP /min g/s % °BTDC STAMP °KW °KW °KW °KW STAMP /min % mbar mbar
    0.87 2000 38.56 86.7 14.3 0.27 0 0 0 0 0.56 1960 81.2 1740 1040
    1.78 2280 54.19 91 11.3 1.17 0 0 0 0 1.47 2200 106 2340 1270
    2.69 2640 77.61 96.1 11.3 2.08 0 0 0 0 2.39 2520 130.1 2420 1560
    3.59 3080 129.44 100 0 2.99 0 0 0 0 3.29 2920 183.5 2480 2100
    4.5 3840 163.92 100 8.3 3.89 0 0 0 0 4.2 3680 191.7 2370 2500
    5.4 4320 185.08 100 11.3 4.79 0 0 0 0 5.1 4120 191.7 2370 2490
    6.3 4920 205.86 100 8.3 5.71 0 3 3 0 6 4720 191.7 2410 2460
    7.21 5440 216.36 100 8.3 6.6 0 3 3 3 6.91 5280 191.7 2400 2360
    8.12 5920 223.42 99.6 13.5 7.52 0 3 3 3 7.81 5760 191.7 2370 2240
    9.02 6360 221.64 100 17.3 8.44 0 3 2.3 3 8.72 6200 188.7 2310 2150
    9.92 6520 0 5.9 6 9.32 0 2.3 2.3 2.3 9.62 6600 177.4 2200 2110
    10.83 4920 163.75 100 12.8 10.22 0 0 0 0 10.53 5280 39.8 1670 1070
    11.73 4480 11 6.7 3.8 11.14 0 0 0 0 11.43 4840 12 980 1350
    12.64 3720 8.28 6.3 3 12.04 0 0 0 0 12.34 3880 13.5 980 1050
    Sep 2012
    West midlands
    368
    January 2013 13:11:29:10074 VCDS Version: Release 10.6.4 Data version: 20110418
    '118 Group B: '002 Group C: '031
    RPM Temperature Load Absolute Pres. RPM Load Inj. On Time Mass Flow Lambda Factor Lambda Factor
    TIME TIME
    /min °C % mbar STAMP /min % ms g/s STAMP
    1720 12 94.5 1190 75.81 1800 100.8 10.2 36.86 75.21 0.852 0.86
    2000 12 94.5 1350 76.71 2120 121.1 12.24 51.03 76.12 0.86 0.844
    2360 12 94.5 1620 77.63 2480 149.6 15.3 76.94 77.02 0.844 0.844
    2800 12 94.5 2170 78.53 2960 191.7 20.06 128.28 77.93 0.805 0.844
    3720 12 80.4 2540 79.44 3880 191.7 22.78 177.89 78.83 0.875 0.844
    4120 12 78.4 2510 80.34 4320 191.7 22.1 183.67 79.74 0.821 0.836
    4720 12 80.4 2470 81.25 4960 191.7 21.76 207.25 80.64 0.813 0.828
    5320 14 83.1 2390 82.15 5520 191.7 21.08 219.25 81.55 0.813 0.821
    5880 15 91 2250 83.07 5920 175.9 17.34 224.86 82.45 0.797 0.813
    5200 14 0 1270 83.96 4440 12 0 5.56 83.36 0.906 0.899
    Sep 2012
    West midlands
    368
    Well knock sensor 1 signall too low was on vcds today so I was right knock sensor for cylinder 1/2 up the duff!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,584
    Quote Originally Posted by darren t View Post
    Might not be the sensor... they are fairly reliable... could be the wiring... I have had this on knock sensor 1 (a too high fault in my case), rewired the sensor and it went...
    <tuffty/>
    Sep 2012
    West midlands
    368
    <tuffty/>
    either way ill replace it for peace of mind explains those silly cfs!!!
    Sep 2012
    West midlands
    368
    So I replaced sensor fault gone but now I'm hitting over boost in low revs as you can see I done 2/3 logs full bat no over boost I think it a massive boost spike as my engine bay was so hot it was unreal ??is my boost well over requested????so my actuator preload is still too much so it cant open waste gate flap enough in low revs?im I need of a map I know but for now I want too be running car safe as I done a fuel graph well lamba requested ect graph wasn't good fuel is all over the place so I am now sure in my mind its worth spending the money even though its quick ill be running safer power for longer hopefully did bill map westys aswell??
  1. NEW ENGINE - ADVISE NEEDED!
    By CharlieT in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2008, 13:40
  2. Buying advise needed
    By spaceace in forum General Chat
    Last Post: 26th November 2007, 16:30
  3. Advise needed please!
    By Luckymonkey in forum Detailing
    Last Post: 19th April 2007, 10:29
  4. Newbie!! Advise needed on alloy wheels?
    By audicoupegt in forum The Welcome Section
    Last Post: 23rd August 2006, 23:09
  5. ADVISE NEEDED PLEASE
    By Dannycanyon in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2005, 16:45
